diyAudio Sponsor
Old 17th January 2009, 10:49 PM   #1
Default preamp for a JE LABS 2A3DX amp
After building my JE LABS Stereo SE2A3dx amp (see http://members.myactv.net/~je2a3/se300b.htm)
I am toying with the idea of building a preamp in order to improve the sound (if it is possible, I’m very happy with). I have seen a lot of schematics (too many) and I need advice to know which will match better with my amp. My source is an ARCAM CD73 CD player.
Possible preamps:
Salas’ 6V6 preamp
Hendram’s E182CC preamp (seems easy)
SY’s ECC88 Heretical preamp
TNT Preamble N 7586 preamp
Triode Dick Cleo 6 6N30P preamp
Libero’s 6H30 preamp
Pete Millet Low-mu preamp
Moebius 6AQ5 preamp
Andy Evans 10Y preamp
Poindexter 6T4 preamp
12b4A preamp (there are a lot)
Gavin
ArnoldC
Eliduttman
JDev
Guldbrandsen
Please, your advice
Old 18th January 2009, 12:04 AM   #2
korneluk's Avatar
Hola lquintas,
From my experience driving amps with 6SN7 inputs, you should look at a DHT-based preamp - i.e. 26, 10Y, etc.
If you want to avoid the hassle of dealing with hum and microphonics, the go straight to the 27 tube. Here's a simple one:
27 IDHT Parafeed Preamplifier
http://nullspace.us/27.html
I've personally used an Emotive Audio Erato with a 6SN7/45 Jeff Korneff amp and found the combination stunning.
Saludos y buena fortuna en el 2009,
--josé k.
Old 18th January 2009, 02:03 PM   #3
Thank you Korneluk, I didn't know the preamp you propose.
Best wishes for you too.
Old 18th January 2009, 04:55 PM   #4
Senor,
The JE Labs schematic you linked shows a 3 stage integrated stereoblock amp. I suggest that you look at something other than a preamp to improve overall system performance.
What sort of volume attenuators are you using?
ARCAM CDPs have solid reputations, but you may be able to improve things in the analog buffer amp area. The DECWARE DIY ZKIT4 has the sort of small footprint needed for inside OEM enclosure CDP modifications.
Eli D.
Old 18th January 2009, 06:59 PM   #5
Thank you Eli. If my system doesn't need a preamp, perhaps I'll try a phono preamp, but I'll have to get a new turntable.
The volumen pot I have is a dual Alps Blue Velvet. Would an step attenuator worth it?
Recommend a Good Preamp for Pass Labs Amps misterdoggy Pass Labs 4 20th January 2007 04:43 PM
FS: Pass Labs X2 preamp Studley Swap Meet 0 18th January 2007 10:53 PM
Hajdinjak Labs Tube Preamp HL Reference Mitko1 Swap Meet 0 10th September 2006 06:52 PM
Pass Labs BOZ Preamp for sale Zodiac Swap Meet 0 12th October 2004 07:00 PM
Page generated in 0.08540 seconds (77.44% PHP - 22.56% MySQL) with 10 queries
