becki200 said:Hi Nigel, what is a soft limiter? I dont want to build a buffer with lethal voltages, the EF95 really works with 12 Volt. And it will cost a few Euros 2 Tubes 2 Sockets some resistors and some caps
maybe 10 Euros will do. Best regards Thorsten
If your valve works with 12 volts then I would use that.
A soft limiter basically rounds off the top of the waveform instead of squaring it off.
Sadly I cant find the cct diagram of the one I used to use.
But it was an opamp amplifier with two transistors in the feedback loop with a rounding off level set by a pot.
