| diyAudio Sponsor | ||
I am about to start experimenting with PLLXO (passive line level crossover) and to select the right component values to start with, I need to know the input impedance of my Simple SE amp. I lack the tools to measure this properly myself.
Surely, someone here knows what the nominal input impedance of this amp is? Thanks. |
#2 |
It's the value of the input tubes grid grid leak resistor (the pull-down resistor). Which is 220k, if you built it as shown on the Tubelab website.
http://www.tubelab.com/AssemblyManua...ematic_SSE.htm If your using a volume control, place the cap between the potentiometers wiper and R11. Do the same for the other channel with R21. |
| Input impedance of tubelab simple se | pforeman | Tubes / Valves | 1 | 24th May 2009 12:42 PM |
| Input impedance of tubelab simple se | pforeman | Full Range | 2 | 24th May 2009 05:10 AM |
| simple impedance question | patchwork | Multi-Way | 29 | 1st January 2007 11:29 PM |
| a simple question about speaker Impedance?? | Minion | Full Range | 8 | 23rd October 2006 06:08 PM |
| input impedance | castela | Solid State | 2 | 17th January 2003 07:02 PM |
| Page generated in 0.06416 seconds (67.51% PHP - 32.49% MySQL) with 10 queries |
