| diyAudio Sponsor | ||
Hi, somebody can help me to find the best plate voltage for 6dj8 runing at +-6ma with plate CCS (1st input stage preamp class A) .
Thanks npr |
#2 |
Before somebody else jumps in and tells you exactly where you should run your tube I'd like to encourage you to experiment a bit. It's easy to try different operating points and ultimately, it's the only way to know for sure - and especially simple if you already know the current you want to run.
Put a constant current source on the plate of the tube set for your desired 6mA. Then, just by changing the cathode resistor so that IR=Vbias wherever you want to check out on the plate curve chart at 6mA you can get different corresponding plate voltages. It frees you up from depending on people's advice that may not actually work as well for your application as it did for theirs. It's also a good part of the fun. |
#3 | |
Aerodynamics are for people who can't build engines. Enzo Ferrari |
#4 |
To operate 100v\6ma, in the cathode I have 270r. In parallel with a capacitor of 1,5uf, to improve the medium frequencies significantly. The tube that I have (Tronal), has excellent basses, and high, but it asks for a little in the medium, from there the reason of the capacitor.
Thanks, npr |
#5 |
With that value of cathode bypass, you have a preamp with a fixed tone control with a 400-500Hz turnover. Is that intentional?
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache |
#6 |
Hi Sy. Yes. In the calculations that I made I got 2500hz (I can be wrong).
Of the few tubes (preamp) that until today I tested, 6dj8 is distinguished for the basses, but it loses a little in the remaining frequencies (my opinion). I like to place the control of volume between the 1 and the 2 stage, with 10k or 4k7 pot, and for this requirement of current I think that 6dj8 is a good candidate. |
#7 |
Sy, your calculations are correct.
#8 |
Well, maybe I'm not correct. If you're following the CCS'd 6DJ8 with a 4k7 pot, that pot is effectively the plate load. This means that the tube's impedance shunts the 270R with 4k7/33 = 142R. So the effective resistance is 142R in parallel with 270R = 93R. That puts the turnover at 1140Hz.
#9 |
If you connect the pot after a coupling capacitor then your initial calculations remain valid?
(1\(2*pi*270*0,0000015)=393hz |
#10 |
Assuming that the f3 from the coupling capacitor is well below the turnover, then the pot is effectively the plate load for purposes of the calculation (and for purposes of load lines).
| SE Tube Preamp circuit using 6922/6dj8 at low voltage(24volt) needed! anyone? | tone | Tubes / Valves | 7 | 20th February 2010 12:11 AM |
| Plate Current VS Plate Voltage Graphs | Captn Dave | Tubes / Valves | 2 | 13th February 2009 08:57 PM |
| Low Voltage Plate Follower 6DJ8 Buffer Power Supply | mwl6m | Tubes / Valves | 50 | 3rd August 2007 07:50 AM |
| 6DJ8 preamp voltage? | needtubes | Tubes / Valves | 1 | 2nd April 2004 09:06 AM |
| 6DJ8 cathode heater voltage question. | Morse | Tubes / Valves | 13 | 30th January 2003 07:59 PM |
| Page generated in 0.09779 seconds (77.55% PHP - 22.45% MySQL) with 10 queries |
