| diyAudio Sponsor | ||
Is it possible to use fixed bias and cathode bias on a tube at the same time? I want to get part of my bias from a resistor for local feedback but also use fixed bias with a servo to keep the Ip set at a precise point.
'Musicality' is the last refuge of a tweak. --PETER ACZEL, The Audio Critic |
#2 |
Yes, the total bias voltage can be obtained from more than 1 source.
Combination bias can be a useful tool. You described 1 benefit, local current NFB (degeneration), which reduces distortion. Another benefit of combination bias is stabilization of the chosen operating point. Many tube types have comparatively low grid leak resistance value limits, when "fixed" bias is employed. Employing combination bias safely allows a rise in the grid leak resistor's value.
Eli D. |
#3 |
Ok, so I will give it a try. Thanks for letting me know I am on the right track.
| Capacitors for sale mixed bag | captaink | Swap Meet | 2 | 18th January 2012 06:23 AM |
| Mixed signals??? | genmin | Car Audio | 4 | 12th February 2009 06:58 PM |
| Voltage amp mixed with current amp? | kubeek | Solid State | 3 | 27th June 2006 07:36 PM |
| Mixed feedback | Bazukaz | Planars & Exotics | 8 | 17th May 2006 07:39 AM |
| Page generated in 0.06221 seconds (75.63% PHP - 24.37% MySQL) with 10 queries |
