blind test tube preamp free for all
Old 14th January 2009, 05:50 PM   #21
adamus is offline adamus  United Kingdom
its is a different pinout. But the the valves parameters look similar.
Old 15th January 2009, 04:49 AM   #22
mach1 is offline mach1  Australia
Banned
The thing I find both interesting and really refreshing is that this amp does so many things considered wrong by ‘experts’ and yet obviously manages to sound excellent.
Paralleled tube sections are supposed to lose detail and refinement and blur the soundstage. High resistance in the psu is considered heresy by some, and chokes are generally considered superior to high value resistors in this location. Chokes or CCS are also considered by many to make better plate loads than resistors, and LEDs or battery biasing of the cathode is often considered superior to a conventional RC network.
I guess the outcome adds some weight to the ‘it ain’t what you do, it’s the way that you do it’ philosophy of amp construction.
Old 15th January 2009, 06:58 AM   #23
analog_sa is online now analog_sa  Europe
analog_sa's Avatar
You may be right. We don't know if it sounds excellent; it merely sounds better than other preamps which may be even more compromised and built with inferior parts. It will be very interesting if the builder explains his prefences.
Old 15th January 2009, 04:45 PM   #24
Jeb-D. is offline Jeb-D.  United States
Jeb-D.'s Avatar
x2
Some times you just have to keep it simple and old school
Old 6th February 2009, 08:20 AM   #25
barossi is offline barossi  Germany
Originally posted by hendram
each channel tube is parareled..
very nice indeed :-)
Some questions:
Do both cathodes share the 330 Ohm Riken resistor and 470uF?
Do both anodes share the same 10K resistor!?
Kind Regards
Hauke
Old 6th February 2009, 10:29 AM   #26
On Hiatus
SY's Avatar
We also don't know which preamp sounded the most like the input signal.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 16th February 2009, 09:35 AM   #27
i quickly build this nice preamp!
The sound is very fast and crystal clear; but i have microphonic effect with my E182CC.
My brands are: Mullard and Valvo (green)
Could you observed microphonic effect ?
KR
Hauke
Old 25th August 2010, 04:56 PM   #28
bambadoo is offline bambadoo  Norway
I also built this but with 6463 tubes and AN m2 psu. Sounds very good. Very musical.
Old 25th August 2010, 11:54 PM   #29
Miniwatt is offline Miniwatt  Netherlands
Miniwatt's Avatar
Congrats! I like the simplicity of your amp, both the circuit and the build.
Old 26th August 2010, 03:51 AM   #30
DualTriode is offline DualTriode  United States
Thumbs up The Spirit of DIY
Originally Posted by hendram View Post
my simple line stage E182CC preamp won in blind test tube preamp free for all event in Jakarta indonesia on Des 08.
http://jimmyauw.com/wp-content/uploa...amp-e182cc.jpg
Jimmy’s Junkyard Blog Archive Pre Amplifer “Free-for-All” Blind Test Session
Hello hendram,
Simple elegance prevails.
DT
All just for just for fun!
blind test tube preamp free for allHide this!Advertise here!
Amplifiers, AB comparative testing, a blind test method. destroyer X Solid State 34 29th September 2009 12:39 PM
Audio test CD - Free for anyone to use tuck1s Parts 1 16th September 2008 11:39 PM
Your free test tone CD DrFrankenstein Music 0 8th February 2007 09:20 PM
Am I blind? (shunt reg's for preamp) Onvinyl Power Supplies 5 25th July 2005 08:19 AM
FREE Audio Test CD!!! seangoesbonk Everything Else 13 16th May 2005 01:39 PM
