| diyAudio Sponsor | ||
Is there a good method to estimate the Miller capacitance of a triode strapped pentode?
http://www.ecpaudio.com |
#2 |
diyAudio Moderator Emeritus
It makes sense for it to be Cg1g2 X stage gain. I'm guessing that the plate is too far from g1 for there to be a significant capacitance between them, but I could be wrong.
#3 |
That sounds right to me; after all, that's the idea of a tetrode in de foist place, no? The problem would be to find this capacitance. The datasheets very seldom give such data for trioded pentodes; we're lucky to get plate curves.
I wonder, would this spec have to be tested for on a hot tube in-circuit, or could we just stick an LCR meter on the appropriate pins on a cold tube sitting on the bench? Aloha, Poinz AudioTropic |
#4 |
Hi Ponz,
I don't see why the tube has to be hot to get this measurement. Temperature would make a difference, I suppose, but it should be slight. |
| Pentode Miller Capacitance, and which spec value to use? | flysig | Tubes / Valves | 5 | 30th May 2009 09:59 PM |
| Wanted Triode strapped curves for pentode of ECL82. | Shoog | Tubes / Valves | 2 | 28th March 2007 09:03 PM |
| PP-Triode , PP-UL , PP-Pentode-strapped-as-Triode | percy | Tubes / Valves | 23 | 22nd January 2007 01:36 AM |
| Recommendations needed for designs of PP pentode strapped as Triode | percy | Tubes / Valves | 24 | 22nd October 2004 10:03 PM |
| E180F triode-strapped. | jim | Tubes / Valves | 15 | 16th September 2003 12:00 PM |
| Page generated in 0.07581 seconds (71.44% PHP - 28.56% MySQL) with 10 queries |
