| diyAudio Sponsor | ||
Hi I need your comments on this page, providing a good explanation of why wire wound resistors and pontentiometers are better for audio applications.
http://www.aikenamps.com/ResistorNoise.htm
Great DIY site: http://www.neazoi.com |
#2 |
High thermal dissipation available.
More tolerant of voltage on the wiper. Lower noise. For parts over ~10K ohms inductance not a factor @ audio frequency. Also not a problem in triode plate loads. Not good choice for grid, plate, cathode stoppers. Here low inductance and short leads are critical.
Be sure your foil hat has a good low impedance ground. |
| FS: Vintage Precision Wire-wound Resistors | theAnonymous1 | Swap Meet | 11 | 20th June 2009 09:41 PM |
| Why not wire wound potentiometers for volume? | tem00 | Chip Amps | 18 | 16th January 2009 01:48 PM |
| Wire Wound Resistor Failure? | jjai | Solid State | 6 | 3rd March 2005 07:32 PM |
| Wire wound pots as volume control ???? | Shoog | Everything Else | 4 | 29th April 2004 05:09 PM |
| Voice coil wound with steel wire. | Circlotron | Multi-Way | 6 | 20th February 2003 07:18 PM |
| Page generated in 0.05738 seconds (72.08% PHP - 27.92% MySQL) with 10 queries |
