diyAudio Sponsor
Old 12th January 2009, 03:16 AM   #1
Will is offline Will  Malaysia
Default Single supply 6922 buffer with 2SK CCS
I'm a bit poor on this tube topic so please help me out.
The circuit on the right (dual supply buffer) has been done before so I guess it's a working model.
My question is, can the diagram on the left using single supply be used with the same CCS?
The reason being I have the trafo and choke to provide a good 80V supply and if possible I would like to use high voltage PIO as ouput caps.
Many thanks.
regards,
Will
Old 12th January 2009, 03:29 AM   #2
WT is offline WT
I don't think you have enough voltage to make the ccs work for the single supply.
Old 12th January 2009, 03:33 AM   #3
How much more voltage do I need to make it work?
regards,
Will
Old 12th January 2009, 03:44 AM   #4
Will,
Aside from the lack of Volts, the single supply circuit will NOT work, as drawn. Where's the negative bias on the triode's grid? A DC coupled I/P is possible, only when a bipolar PSU is employed.
What are the ratings of the power trafo's rectifier winding? Depending on the rectifier winding's wiring, it may be possible to get the Volts you need, either by bridge rectification or Greinacher voltage doubling.
Eli D.
Old 12th January 2009, 03:50 AM   #5
WT is offline WT
You can use -6V on the tail of CCS by using the V from heater supply. Also take out the 6.8K resistor as well, or change it to 10 ohm or 1 ohm so you can use it to measure current.
Another way is to replace all of the ccs with choke which I think will make this circuit more elegance.
Old 12th January 2009, 04:43 AM   #6
Originally posted by Eli Duttman
Will,
Thanks for the info, do excuse my lack of knowledge.
I have a 120v trafo (secondary) and when after full wave rectification will produce 120x1.4 = 168v. Hence plenty of headroom to bring voltage down. I have a 50H choke. Any suggestion?
regards,
Will
Old 12th January 2009, 04:46 AM   #7
How would you calculate the choke value? Assuming I want to bias the tube at 15mA.
regards,
Will
Old 12th January 2009, 03:01 PM   #8
revintage's Avatar
The 6922 is totally unusable if you want to make single supply CF.
If you use a pair of 12B4A with I=10mA you will get 7Vrms with Zout=150ohm.
If you use a 6N30P you will get 3Vrms with Zout=120ohm.
Brgds
Lars
Old 12th January 2009, 03:07 PM   #9
leadbelly's Avatar
Why? The ECC88/6DJ8/6922... family are great for CF's.
Aerodynamics are for people who can't build engines. Enzo Ferrari
Old 12th January 2009, 03:48 PM   #10
revintage's Avatar
Hey Leadbelly,
Read the whole sentence ! It says "single supply" as in the Wills left picture. Otherwise you are right, it is really good as CF (if you happen to like CFs).
If one decide to use a input cap and lift the triodes grid from ground potential it will not be a problem to use 6DJ8.
Brgds
Lars
6N1P for buffer instead of 6DJ8, 6922 JojoD818 Tubes / Valves 39 28th April 2010 12:17 AM
6922 tube buffer sarrisk Tubes / Valves 6 20th October 2008 12:46 AM
Heater supply recommendation for 6922? leadbelly Tubes / Valves 18 20th March 2007 02:14 AM
Tube Buffer for CD-PRO2M (6922) Rarkov Tubes / Valves 22 4th March 2005 06:37 AM
power supply for 6922 mu follower AudioGeek Tubes / Valves 5 30th June 2004 03:25 AM
Page generated in 0.10212 seconds (78.45% PHP - 21.55% MySQL) with 11 queries
