| diyAudio Sponsor | ||
#21 |
Dear Osprey,
Many thanks for your answers and explanations. I am thinking about headroom and need an advice if I am doing it correctly. So, I made an operational point analysis using ECC99 plate characteristics, which are similar to 6BL7. I used a load line based on: E = 300V Zp = 20k Zs = 600 RH = 300 (HD 650) RL = RH x (Zp/Zs) = 10k I chose Io = 15.5mA based on my transformer rated current and Ug = 4V. Then Uo = 146V (see PDF attached) Let’s assume that input signal have average level 200mv RMS. From the PDF we can see that grid voltage can change from -0 to -8V (peak values) or from 0 to -5.6V RMS or with amplitude of 2.8V RMS. So, 20log(2.8/0.2) = 23dB Does it mean that the amplifier has headroom of 23dB? Thank you, Igor |
#22 |
Excellent choice of the ECC99 tube; it should work perfectly for this application. Your load lines look correct and all your computations seem OK. The only thing I would caution you about is the RL. This can only be considered an approximation. In reality it could look very different to the tube.
So now it is time to breadboard the amp. Build it up with the components you have chosen, but use a 1k ohm linear pot for the cathode resistor. You should have about 300V on the plate. Adjust the pot for your chosen current of 15.5mA which is correct for you OP trans. This should give about -4V on the grid. You can go up to 20mA as you know for the plate current. Once you have determined the currect cathode resistance measure the pot and put in a fixed resistor of the nearest value. You will need a volume control pot too. 50k or 100k will work fine. With both channels working on the breadboard you should be able to listen to the amp to see what you think about the sound. |
#23 | |
Again thank you very much for your comments.
Thank you, Igor |
#24 | |
#25 | |
Many thanks.
Thank you, Igor |
#26 |
You should have massive headroom, but you won't know the actual numbers until you build the unit and measure the voltages.
| Looking Sennheiser KE 4-211-2 mic datasheet | TheSpark | Parts | 2 | 5th November 2011 08:22 AM |
| FS Sennheiser HD650 | markmelheim | Swap Meet | 8 | 24th March 2008 09:15 PM |
| sennheiser lucas dsp pro | Sandor | Everything Else | 0 | 7th May 2005 10:06 PM |
| Sennheiser Mic | george a | Everything Else | 1 | 27th April 2005 12:43 AM |
| Sennheiser HD-490 Modding | li_gangyi | Everything Else | 2 | 6th November 2003 02:18 PM |
| Page generated in 0.09069 seconds (70.91% PHP - 29.09% MySQL) with 11 queries |
