diyAudio Sponsor
Old 11th January 2009, 09:06 PM   #1
Fuling is offline Fuling  Sweden
Default Edcor specs?
Hi
I recently ordered some Edcor iron to build a cheap IT-coupled PP amp, two XSM15K/15K ITs and two XPP15-8-8K OPTs to be specific.
I´m not expecting miracles from >13 bucks ITs and >20 bucks OPTs but I´ve used their small SE OPTs before and found them very good for the price.
Question is: How much voltage can those coupling transformers handle before they saturate or otherwise misbehave?
I´m talking voltage swing, not insulation strength.
I would like to use triode wired 6CM5s as output tubes but they require -40V or more on the grids and I´m not sure the transformers can swing that high.
I understand that keeping DC out of the transformers is a good idea so the driver stage will be either a balanced PP stage or an SE parafeed thing using the transformer for phase splitting.
Alternative output tubes might be 807 (-22V) or 6AQ5 (-15) but I would definitely prefer 6CM5 (EL36).
Edcor In SE Guitar Amp Trout Tubes / Valves 9 14th September 2007 10:59 PM
WTB: Edcor XSE15-8-5K Fuling Swap Meet 0 23rd July 2007 09:10 PM
Edcor outputs? kegger Tubes / Valves 4 3rd February 2007 04:35 PM
Edcor OPT's bloozestringer Tubes / Valves 23 3rd January 2007 05:27 AM
More Edcor XSM10K/10K Specs valveitude Tubes / Valves 8 16th October 2006 10:02 PM
Page generated in 0.06351 seconds (67.91% PHP - 32.09% MySQL) with 10 queries
