diyAudio
diyAudio (http://www.diyaudio.com/forums/)
-   Tubes / Valves (http://www.diyaudio.com/forums/tubes-valves/)
-   -   hook up wire (http://www.diyaudio.com/forums/tubes-valves/136342-hook-up-wire.html)
Burnedfingers 11th January 2009 06:39 PM
hook up wire
where would I find a reasonably priced hook up wire that will be good with voltages up to 500 VDC? Could someone suggest something that doesn't cost an arm and a leg?
lowtherdream 11th January 2009 07:10 PM
From Antique Electronic Supply
Lacquered Cotton Braid Solid Core Wire
#20 solid copper wire with modern insulation and lacquered cotton braid finish.
25, 50 or 1000 foot spools, assorted colors.
http://www.tubesandmore.com/
or
http://www.radiodaze.com/wire-cloth_covered.htm
mach1 11th January 2009 10:04 PM
ebay: there is usually a large amount of teflon (or similar) silver plated copper wire at very reasonable prices. Good choice of gauges and construction.
MashBill 12th January 2009 12:11 AM
I get mine HERE.
It is very easy to work with.
Bill
Eli Duttman 12th January 2009 03:58 AM
DIYer resource extraordinaire McMaster-Carr carries MILSPEC, PTFE insulated, stranded, Silver plated Copper, wire rated for service at 600 VAC. The price for 20 AWG is $0.55/ft.
lowtherdream 12th January 2009 06:34 AM
If you check the prices at Antique Electronic Supply,
the 20AWG solid cloth covered copper wire is 0.18 cents a foot if you buy a 50' roll.
$8.78 for 50', that's a grest price !
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2016 DragonByte Technologies Ltd.
Copyright 1999-2016 diyAudio
