| diyAudio Sponsor | ||
Well, at least for the most part. Needs a few tweaks and such here and there and a few unused wires to tie down, but it seems to play music, at least for a whole CD, without bursting into flames since I put it in a metal chassis. I've got a pop at power-off I need to deal with though.
One question: I don't have the (-) terminal of the speaker jacks grounded, just floating. I've heard and seen it done both ways on amps with no feedback, but if I do would I run a seperate wire to the star ground, or tie them seperately (or together) on the chassis near the jacks? A big thank you to Tom McNally and Norris W. for all their help in answering dumb questions along the way. FWIW it's a Darling with a 5V4G rectifier. I had to use a bucking trafo to get the B+ down into a reasonable range with my high mains voltage and the parts I had on hand. I went with the junkyard industrial look I guess. Tried to keep it simple. ![]() ![]() ![]()
#2 |
That's a cool chassis - where'd ya get it?
#3 |
Just the standard Hammond 10x17x3 aluminum. I sanded it with 220 grit sandpaper in 4 different directions then sprayed a couple of coats of art fixative on it.
It's OK for a first build, but I don't think I'll use one again. They are quite thin. This amp only wieghs about 20lbs, so it's not really a problem, but anything heavier and it would be I think. |
#4 |
Nice! In my last build I left it floating. For the pop at turn on/off I believe people put a .1uf cap across the switch. The black steel chassis from Hammond are nice and will stand up to 100 lbs of Iron without flexing or bending. (At least so far
#6 | |
I'm using a DPST switch, switching the hot and neutral. Tried putting a 0.01uF/1000V disc cap across the hot terminals on the switch, but didn't like the fact that if the switch was off I was getting 123V from the amp side of the switch to ground. Put back in a replacement switch of the same type and measured virtually nothing. I think I'll just shut off the amp while the music is playing and call it good. |
#7 |
Nice build you did. How does she sound..? It should sound wonderfull to say the least as I know what they can do. I am running the 1626's 220v @ 23ma w/ 5k 8ohm ancient OT's,I think, I would have to check notes on the op- point. What is your op-points..?
J & G |
#8 | |
Thanks. Take a look at my website for the schematic, etc with OP points on it. Just click on the little pics to see big ones. http://pedalforroses.homestead.com/PowerAmps.html |
#9 |
Schematic updated on website. I switched from the DPST to a SPST for the hot leg instead of switching both hot and neutral.
http://pedalforroses.homestead.com/D..._w_12V_FTf.GIF |
| I want to try and build my own DAC | gareth | Digital Line Level | 3 | 3rd July 2009 03:20 PM |
| ZV9 build | ingi | Pass Labs | 8 | 6th August 2006 02:40 PM |
| build my first full ranger,let's build another one:a small fullrange high end pc-spea | then_dude | Full Range | 2 | 30th November 2005 07:54 AM |
| Do i need to build main supply (240v) filter?Or build power distribution? | thomgun_lc | Chip Amps | 9 | 16th September 2005 09:52 AM |
| Page generated in 0.10818 seconds (79.70% PHP - 20.30% MySQL) with 10 queries |
