| diyAudio Sponsor | ||
I think it's a good idea to ground a chassis with a 3 prong plug for safety reasons. I'm using a bridge rectifier and a regulator on the current build. It just occured to me that I might have a problem in the making.
If I solder the B- to the chassis and then go to ground with a 3 prong plug, have I not shorted out the bridge diode between the AC neutral and the B-, given that the AC neutral and ground are bonded at the circuit box? Is that question clear? Of the four diodes in the diamond shaped bridge rectifier circuit that we are all familiar with, one of the four stands between the AC neutral and the B-. That's the one I suspect I'd be shorting (through the home wiring) by using the 3 pronged plug. Is this correct and what are the consequences? Thanks |
#2 |
Not to reason to worry.
Provided you are using a normal power transformer, the secondary windings are completely isolated from the primary and from ground, ie. floating. There will thus be no shorting in your amp, nor in any of the other millions in operation with this arrangement. SveinB. |
#3 |
Oh yeah, I forgot to mention that part. No transformer planned; 6GM8s. I'll need an isolation transformer unless I completely isolate the B-? Doesn't sound very safe without one, does it?
#4 |
You must use a transformer for isolation. Your concern sounds as if you intend to directly rectify the mains which is unsafe. Earth ground is used as a voltage reference. Current will flow from and back-to the isolation transformer. Earth ground will just pull the circuit down to ground potential so that it is not floating.
Neutral and earth ground are tied together, but before the breaker. If current flows in the earth ground, the breaker will trip. |
#5 |
NOT SAFE!!!
I suggest some pyrotechnics or firecrackers to make some sparks instead of connecting to electrical supply. Much safer. Svein. |
#7 |
Aside from the EXTREME hazard, using a bridge rectifier directly from mains is just not practical, as both + and - sides of the bridge will be LIVE with respect to ground. Use an isolation transformer. If current is small, use a second 6.3V transformer in reverse from your 6.3V heater winding to give (isolated) mains voltage.
#8 |
OK, thanks for the remarks. Consider me chastened.
Tom, clever idea on the filament transformers. I like that. |
| Chassis Grounding Problem !! | excetara2 | Car Audio | 6 | 28th September 2008 01:04 AM |
| chassis grounding question | mnr102 | Solid State | 2 | 12th July 2008 09:14 AM |
| Grounding chassis | borges | Analog Line Level | 1 | 16th March 2007 08:58 AM |
| Grounding SPDIF and Outputs to Chassis? | mfr | Digital Source | 1 | 25th May 2004 07:05 AM |
| Grounding chassis | Per | Multi-Way | 1 | 17th December 2002 10:21 PM |
| Page generated in 0.08461 seconds (77.86% PHP - 22.14% MySQL) with 10 queries |
