High-power amplifier using transmitting tubes
Old 8th January 2009, 09:34 PM   #1
Michael Koster is offline Michael Koster  United States
Michael Koster's Avatar
Default High-power amplifier using transmitting tubes
Here is an amplifier project I'm starting to put together. It uses all thoriated tungsten filament tubes,
and it's a high power amplifier, hence the name "THOR". Attached is the current working schematic.
Concepts:
- High power, high fidelity audio amplifier using transmitting tubes
- Beam tetrode push-pull output in class AB2 with local plate-grid feedback (O.H. Schade style)
- 2 stage DC driver in class A2 "zero bias" with parafeed transformer coupling to output stage
- MOSFET active anode loads and grid drive buffers to enable linear operation in A2/AB2
- Reasonable power efficiency to allow operation from a single 120 volt AC circuit < 1500W max
- Stable operating points and rated for CCS
Theory of operation:
The driver section is a 2-stage direct coupled amplifier with MOSFET active loads and parallel
feed output. The first stage is an 801A operated in zero-bias. The signal source must be capable
of operation into 600 ohms in order to supply <1mA of grid current with low distortion.
~5V-10V p-p input signal is needed for full output power. The stage voltage gain is about 8.
The 801A operates into a stacked fixed-reference voltage follower/anode load. This
functions like a gyrator and mu-follower with a fixed DC bias to the grid if the next stage. The
gyrator provides a high impedance load to the 801A anode and the mu-follower provides
low impedance drive for linear grid swing of the 3C24 in class A2.
The 3C24 driver stage also operates in near zero-bias class A2 and also works into an active
load. This stage acts more like a SRPP or totem-pole with the 3C24 and the MOSFET driving
opposite current swings into the load. This results in effective output impedance of Rp/2 or a little
below 5K ohms using the 3C24 to "play through" the finite inductance and capacitance of the IT.
This stage needs a huge voltage swing to allow the output stage to use local feedback to emulate
low mu, low Rp triode operation.
The output of the driver is parallel fed into the LL1660S/PP interstage transformer. The audio
signal here is up to 950V P-P for a single ended drive stage or up to 1650V P-P for a push-pull
drive stage using a pair of 3C24s. (The push-pull drive stage option mirrors the entire 2 stage
driver for each channel). The stage voltage gain is about 23, for a total voltage gain of about 184
from input to IT primary.
The output section uses a pair of 4-65As in class AB2 push-pull. The basic topology is as shown
in O.H Schade's "Beam Power Tubes", having plate feedback AC coupled to the interstage drive
transformer. Grid drive current comes from a separate power supply through the class A totem
pole followers. These have about 10R to the positive supply and 100R to the negative supply of
effective DCR, and isolate grid current from the drive stage and feedback network. Depending on
the amount of drive voltage available (SE or PP drive stage) the local plate-grid feedback results
in an effective "triode equivalent" Rp of 500-800 ohms driving into 2K impedance, for a damping
factor of 2.5:1 or 4:1. Voltage swing is about 900Vp per anode into 2K for about 200W output
power at the anodes.
Operating all of the filaments at fixed potential allows using SMPS with external chokes to power
the hungry TT emitters.
I just found some output transformers I've been waiting on to proceed with this foolish endeavor.
Now where would I find a worthy power transformer and chokes? I could wire the secondaries of
three 480V/1A control transformers in series and use a bridge rectifier... full signal on both channels
is 550 mA at 1200V. Hmm... 660W in, 400W out... 60% plate efficiency, 65W per 4-65A. Check.
My first decision to maket is SE drive or PP? I'm favoring the PP drive stage because it enable more
local feedback in the output stage and a lower output impedance. However, the SE drive stage
may give the amp a more SE-like harmonic signature and save about 100W of idle power. The PP
drive stage is a more manly option and results in 16 bright filaments, counting the 4 damper diode
B+ rectifiers.
I'm thinking about building it vertically on a trolley ;-) so as to
have room for proper power supplies.
Michael
Old 8th January 2009, 10:13 PM   #2
JoshK is offline JoshK  Canada
Interesting. I don't confess to understand the driver one bit. Boat anchor territory 4sure.
You driving electrostats?
Old 8th January 2009, 10:30 PM   #3
kenpeter is offline kenpeter  United States
Regarding 6N170 antitriode bias...
The gate ain't conducting any DC,
how long you think a 12V keyfob
battery might last in that app?
Duracell MN21 or whatever...
Well insulated of course!
Old 8th January 2009, 10:40 PM   #4
30ma vs 33ma, whats the big difference???
Cascode or UL-Cascode those input tubes
and ditch the pointless 1N60 in between.
Old 8th January 2009, 11:28 PM   #5
The Pentodes Schade back to an EmMU of ~7.9 .
Yet 420 P-P * 7.9 is quite a bit more than B * 2
max possible plate swing...
Or was it only 210 per winding you meant for
that side of the IT? That would be consistent
with the swing you quote for the grid drives...
Old 8th January 2009, 11:28 PM   #6
thoriated is offline thoriated  United States
That much silicon makes me itch.
Old 8th January 2009, 11:29 PM   #7
Its all followers and current sinks here,
no voltage amplification happening in
the land of Sand.
I count two Schaded Pentode Triode
emulators. And one AntiTriode, slaved
to a real Triode. No signal processing
is happening outside of Hollow Glass.
Itch if you want to... All his cheats are
in order, you aren't going to hear them.
Old 8th January 2009, 11:38 PM   #8
Boris_The_Blade is offline Boris_The_Blade  United States
Boris_The_Blade's Avatar
I have a funny feeling you may get some frequency response funkyness with the LL1660 without a resistive load at least on the secondary. Kinda flappin' in the wind there.
Old 8th January 2009, 11:49 PM   #9
The 39K's are a resistive load. And the Schade feedback would
make the 270K plate resistor look to be another 31K in parallel
to GND. Thats one end of the winding...
The other (flapping?) end, is 100R into an insulated Gate with
a following voltage on the other side. That ought to appear as
nearly infinate impedance. You might have a point.
Old 9th January 2009, 12:11 AM   #10
Hmm time to check my work again. I get an actual VA of about
-8 grid to plate and a Schade mu of about 4 when you add about
210 Vpp of feedback to the 210 Vpp grid swing. That's how I got
the 420Vpp per secondary. Actually I think it makes more sense
to talk about peak voltage when discussing class B operation,
but I guess it depends which side of the phase splitter you're on.
Here's the load line
Michael
High-power amplifier using transmitting tubesHide this!Advertise here!
SRS-360 East German transmitting tubes lcsaszar Tubes / Valves 5 19th May 2009 07:18 AM
Tubes for Lumley ST40 power amplifier? john Tubes / Valves 14 1st August 2008 08:20 PM
HIGH Power Sub amplifier? Killjoy99 Solid State 31 18th September 2006 02:54 AM
High power PA amplifier. halvardf Solid State 3 4th February 2004 05:43 PM
Transmitting audio over power line paulb Solid State 3 5th April 2002 09:08 AM
