Comments on 71a PP Pre-amp - diyAudio
Old 10th April 2003, 01:52 PM   #1
Default Comments on 71a PP Pre-amp
I want to build a PP pre-amp. Thinking about using 71a tubes in a push-pull arrangement.
Input phase-splitter tranny and output transformer.
Want to use 150v voltage regulator tubes and MV rectifiers.
I want a total voltage gain of 8-10.
Does anyone see any problems with this??
Thanks!!!
Old 10th April 2003, 02:00 PM   #2
Joel is offline Joel  United States
Joel's Avatar
Default Re: Comments on 71a PP Pre-amp
Originally posted by RichardJones
I want a total voltage gain of 8-10...
I do. Seriously, what's the point of such a low gain pre-amp? If you love your vinyl, then you'll need a lot more gain than that.... and if you use CD's exclusively, you won't need any of that gain.
What is this going to be used for exactly?
Secondly, 71-A's are not cheap, require dc heaters (pain in the butt), and can be fairly microphonic. I love them, but only in power amp duty, with high signal levels.
Joel
Old 10th April 2003, 02:35 PM   #3
Default well....
Because I want to drive a SE MOSFET Class A amp that has a voltage gain of 1. SO.... I need the higher voltage gain.
Total voltage gain of 1.
PP will minimize any hum.
With a input tranny will be high level signals... 5 or so volts input.
plus the fact I allready have 2 matched globe 71a's.
Old 10th April 2003, 02:38 PM   #4
diyAudio Senior Member
fdegrove's Avatar
Default PP
In that case you're still short of another pair of tubes...unless you're going for mono.
Frank
Old 10th April 2003, 02:58 PM   #5
Joel's Avatar
Default Re: well....
...plus the fact I allready have 2 matched globe 71a's.
Good! Then forget the pre-amp idea, and build yourself a 71-A single-ended amp. You'll throw the mosfet amp in the garbage the next day, and never look back.
Let me know if you'd like some ideas/schematics. I've done a lot of work with this tube.
Joel
Old 10th April 2003, 02:58 PM   #6
Default mono?
Nope stereo...
Yeah I realize that I need 2 more tubes... that is no problem.
Other than that... what is wrong with my approach?
I love the sound of 71a's and I love the sound of my 6B4G PP more than my old 6B4G SE amp.
it makes for a simple PS anyway.
Old 10th April 2003, 03:09 PM   #7
Default amp
ok.... also my 6B4G amp has an input stage biased at 4v. (ECC99).
So... I need at least 4v input to my amp.
Still want to do a 71a PP pre-amp. with a 6K:1K output tranny, what input step up phase splitter should I use?
Could get away with total gain of 5 or around there.
power supply is LC stage with a 150v regulator tube and say MV rectifier tubes.
Thanks!!!
p.s. I am going to ignore microphonics for now.
Old 10th April 2003, 03:28 PM   #8
Joel's Avatar
Ok, so basically you want to use four 71-A's, two presumably well made transformer phase inverters, and two high bandwidth output transformers in order to get a gain of 8 to your power amp that was poorly designed to begin with, since it has an input sensitivity of a whopping 4V!
sheesh.
Richard, I'm all for lots of iron, DHT's, and experimentation - but this really seems fruitless.
Old 10th April 2003, 03:32 PM   #9
Default fruitless?
Well it may seem fruitless.... but it sounds damn good. and thats what counts!!!!!
I could get away with a gain of 5.
Whats wrong with lots of iron, MV rectifiers, 4 71a's... etc?????
sounds like fun to me!
Old 10th April 2003, 03:40 PM   #10
fdegrove's Avatar
Default INPUT SENSITIVITY.
So -Vg = 4VDC.
No, not necessarily.
It appears to me that you do not really know the input sensitivity of this amplifier.
While it could be true that it is going to need a 4 Volt input to drive it at full power, concluding that since the bias of the input tube is set at -4V you're going to need at least 4V to drive it is not correct.
Frank
psu comments! lanchile07 Chip Amps 15 27th August 2008 12:20 AM
Comments please on this I/V amp georgehifi Digital Source 9 11th April 2008 02:12 PM
X-over Comments & Help GOWA Multi-Way 23 20th March 2008 01:09 AM
Would appreciate comments... TonyDasilva Digital Source 2 11th August 2005 06:50 PM
my new amp (comments?) LennyK Solid State 16 11th December 2002 04:05 PM
Copyright 1999-2017 diyAudio
