Comments on 71a PP Pre-amp
Old 10th April 2003, 07:06 PM   #21
Joel is offline Joel  United States
Joel's Avatar
Richard, is 1k a low enough output impedance? Perhaps we can get that lower.
Old 10th April 2003, 07:06 PM   #22
fdegrove is offline fdegrove  Europe
diyAudio Senior Member
fdegrove's Avatar
Default BACK ON TRACK.
Well you could do something similar to the 6B4G amp, namely a low mu triode followed by a phase splitter IS and that's all there is to it.
The triode could be any low mu triode you like, you're loosing some gain in the IS but that's no big deal.
Tack a pot on the front and bingo, you now have a preamp, and headphone amp and a miniwatt amp all in one box.
Frank
Old 10th April 2003, 07:11 PM   #23
fdegrove's Avatar
For the inputstage you mean?
Frank
Old 10th April 2003, 07:16 PM   #24
RichardJones is offline RichardJones
1K or less is fine.
How about a 12B4 into a IT, with 71a PP on the outputs?
I kinda liked the idea of a balanced PP design... the PS gets a lot easier.
what would the gain be of the above? Assuming a 1/1:1 IT and say a 8K p-p into 1K output tranny.
any other ideas???
Old 10th April 2003, 08:12 PM   #25
Joel's Avatar
Originally posted by RichardJones
...the PS gets a lot easier...
How so?
Old 10th April 2003, 08:25 PM   #26
316a is offline 316a  England
316a's Avatar
Default power supply
Joel ,
The very nature of push pull means most of the PS crud is cancelled in the output stage . Simple as that
316a
Old 10th April 2003, 08:27 PM   #27
Well I can just use a simple LC supply (any other ripple theoretically gets cancelled in OPT).
Perhaps an LC stage (10H with 47uF cap) with a voltage regulator tube on the output.
thats why...
Old 10th April 2003, 08:31 PM   #28
Default parafeed?
Or can get 2 100H chokes.... a really good OPT... and do parafeed PP output stage....
won't my PSRR be even better then?
But would the parafeed cap go from the midpoint of the output tranny to B+ or the cathodes of the 71a's?
or is this way too much complexity for a pre?
Old 10th April 2003, 08:39 PM   #29
mig-ru is offline mig-ru  Russian Federation
Richard,
i amcurious as to why you need 5v on the output when your amp goes up to 4v? wouldnt the full 5v input drive the power amp out of A class operation, into AB and B? im also curious why you're using output tubes for a preamp, especially when youre going to be running it through a solid state amp after that anyway? just curious, dont mean to sound harsh.
Old 10th April 2003, 08:45 PM   #30
well... i'll probably end up just using my 6B4G PP amps instead....
I kinda like some headroom on my pre-amp... and thats why I have said voltage gain of around 5.
Are there any good higher mu / lower plate resistance DHT out there??? If I go with 46's then mu increases, but plate resistance increases....
txs!
Comments on 71a PP Pre-ampHide this!Advertise here!
psu comments! lanchile07 Chip Amps 15 27th August 2008 12:20 AM
Comments please on this I/V amp georgehifi Digital Source 9 11th April 2008 02:12 PM
X-over Comments & Help GOWA Multi-Way 23 20th March 2008 01:09 AM
Would appreciate comments... TonyDasilva Digital Source 2 11th August 2005 06:50 PM
my new amp (comments?) LennyK Solid State 16 11th December 2002 04:05 PM
