diyAudio Sponsor
Old 6th January 2009, 01:47 PM   #1
Default Adding more power tubes and make a tube amp switching them?
Ive been searching ways to have EL34 6L6 EL84 to a guitar tube amplifier,and be able to change the outuput tubes and not stand-by the amp first.
Ive seen that the heater for each power tubes 6.3V for 6L6 is 0,9A each for EL34 is 1,5A each..So i guess that would overload the transformer,but with an external heater supply at 6,3V and the proper Amps to the multiple tubes and correctly wired would that work?
And if that would do,as about the switching between tube sets,
Ive noticed that a function of the Mesa Boogie mark IV is to "get the tubes out"by removing V6 and V7 pin 8 from the ground.
So a modification like that:connecting all power tubes with an external heater supply normaly,and then choose witch tube will work from a relay switch is theoreticly possible?
Connecting high voltage wires to all power tubes could cause a power transformer overload even if they are not currently used?
Thank you for your time in advance:
Old 6th January 2009, 09:57 PM   #2
Are you proposing to connect all the tubes in parallel,
and selectively heat only one active pair at a time?
Old 6th January 2009, 10:38 PM   #3
HollowState's Avatar
I read it as wanting to heat them all with a seperate filament transformer and switch between tubes one at a time by lifting the cathode connections on all but one pair. And possibly doing it on the fly. Gheesh!
"The supercomputer is technologically impossible. It would take all of the water that flows over Niagara Falls to cool the heat generated by the number of vacuum tubes required." ~ Professor of Electrical Engineering, New York University
Old 7th January 2009, 12:31 AM   #4
Im not sure what you mean "heat"...
If you mean the heater wire pin 2 and 7 of each power tube,im thinking to place another small transofmer 220V ac to 6.3V ac and the proper Amps to support all the tube sets because that so many power tubes will probably overload my stock power transformer,for example 2xEL34 2x6L6.
While playing the 6L6's,then with a relay choose the EL34's without going on standby first.
Ive thought of changing all tube pins from the main input of the PCB with a LOT of relay switches while have them all connected to the heater supply,but when and if i do that the sound will slow rise when switching power tube sets(as when leaving the stand by mode and entering normal mode).But that is the least desirable...
adding output tubes etc to pre amp pforeman Tubes / Valves 1 2nd February 2009 06:02 PM
Tube Noob! need help with tubes lots of tubes therapy_fan Tubes / Valves 15 29th January 2009 09:01 PM
Switching power supply for tube filaments possible??? noyan Tubes / Valves 12 17th September 2008 01:32 AM
Adding tube to Audiosector GC marcus7601 Chip Amps 53 28th August 2008 11:38 PM
Switching power supply for tube-pre JasonLee Tubes / Valves 12 20th March 2007 12:26 AM
Page generated in 0.09800 seconds (59.86% PHP - 40.14% MySQL) with 10 queries
