#11 | |
diyAudio Moderator Emeritus
Frank just beat me to it. Both are indeed depletion mode mosfets.. Cheers, Bas |
#12 |
Sorry, I wasn't paying attention... again...SLAP!
Cool. I need to get some of those! mlloyd1 |
#14 |
diyAudio Senior Member
Bas, May I ask what you're using this CCS for and how you think it impacts on the sound? Just curious,
Frank |
#15 |
Hi Frank,
first question: Not using this particular ccs yet. Still design phase. Dunno yet where or when I will use it. But a guy like me had better do his homework The first time I used the depleted mosfet...single was as a constant current sink in my differential amp second question: No idea. ..it is supposed to sound better than a plate resistor or plate choke. Cheers, Bas Don't forget I am new to diy audio...got to explore.. |
#17 |
The LND150N3 N-Channel Depletion MOSFET is available at Mouser for $0.55 -- featured in this article on Headwize:
http://www.headwize.com/projects/cavalli2_prj.php |
#18 |
If you are gonna abuse a battery, I don't see the point of limiting
yourself to depletion mode devices. The little 12v used for alarm fobs seems a convenient package for that sort of duty. IGBTs seem to have the highest Gm for the least capacitance. You might investigate some of the latest devices. Check IXGT 6N170A, cheap but might be unobtainium in hobby quantities. Do sneak a peek at the spec sheet anyways... If you can live with a mere 600V equivalent part, obtaining a handful of sand to smokeout is a lot less challenging. Nelson Pass once built a very successful IGBT amp back when the one and only complimentary P-Channel IGBT ever offered was briefly available. Like sweep tubes, they are good for more than one thing. Don't let a switching characterization limit your thinking. |
#19 | |
| Floating current source in cascoded output stage | rtarbell | Pass Labs | 0 | 7th April 2006 01:46 AM |
| constant current source | hacknet | Solid State | 19 | 13th March 2006 02:46 PM |
| depletion mode mosfet selection | svokke | Solid State | 0 | 17th May 2004 08:47 PM |
| 12Amp constant current source: OT | harvardian | Solid State | 6 | 12th September 2002 11:38 AM |
| Constant Current Source Circuit | mrfeedback | Solid State | 8 | 22nd April 2002 05:07 PM |
