| diyAudio Sponsor | ||
Hello,
I was hoping to get some advice here on selecting the correct values on a triode (12AX7), I will only be using one stage, and for the power tube I will be using a Pentode tube (5881 I think) cathode biased and maybe running in triode mode. My rectifier will be either a GZ34 or 5Y3. The power transformer is putting out about 410VDC at the first capacitor (no choke). My problem is that I am having some trouble understanding how to plot a load line on the 12AX7 data sheet in order to select the proper values for Rg, Rp, Rk & bypass cap, Co, ect...... How do you guys determin these values or how do you plot the load line? Thanks! |
#2 |
You can go here: http://www.valvewizard.co.uk/ and download the "triode gain stage" PDF. I found that link in a sticky at the beginning of the Tubes section here under "On Line Tube Learning for newbies". The Valvewizard was the best place for me to get some basics happening...
#3 |
Thats a great web site!
Thanks |
#4 | |
As for values for Rg, it's not too critical. For capacitor values, see the "Poles and Zeros" link from the same technical reports column from the above web site. Although I have my doubts as to just how suitable a 12AX7 will be driving a trioded pentode final. 12AX7s have very limited current capabilities and like to see a Hi-Z, Lo-C load, and that doesn't describe the grid circuit of very many finals. |
| How to build a simple balanced mono line mixer | jandalo | Analog Line Level | 4 | 8th November 2008 01:40 PM |
| Capacitance For Mono Block Design | tenderland | Tubes / Valves | 1 | 9th March 2006 02:59 AM |
| How to design the straight load line for choke loaded tube ? | Antonio Tucci | Tubes / Valves | 14 | 30th March 2005 11:05 AM |
| Starting First Amp - Questions on Mono Block Design | jawbreak | Chip Amps | 3 | 12th December 2004 02:00 AM |
| mono block amp | Mark Osborn | Solid State | 11 | 16th March 2001 07:07 PM |
| Page generated in 0.09074 seconds (68.09% PHP - 31.91% MySQL) with 10 queries |
