diyAudio Sponsor
Old 5th January 2009, 07:28 AM   #1
richwalters's Avatar
Default Inverted Mos HV soft start
I get alot of queries from many constructors who cannot abide the concept of using an "n" ch inverted mosfet in the neg leg of a fullwave psu for soft start. The relay coil can be connected to a neg line, a simple B+ self protect for grid bias failure. The possibilities are endless.
So here it is. The power mosfet requires ferrite beads and a snubber (to avoid squegging) can be reclaimed from an old tv line stage and the component ratings obviously rated for the voltages.
I claim no originality for this simple design, only to mention those who meddle with high voltages, know the danger to life darein. It's your life !
richj
what 2' inverted soft dome, cheap robywan Multi-Way 17 7th November 2008 06:34 AM
B+ soft start Gluca Tubes / Valves 2 3rd September 2007 01:04 PM
Need a soft start? maxpou Solid State 19 18th April 2007 09:23 PM
Soft start & Soft Switch circuit: can anybody help? m.parigi Solid State 95 22nd August 2005 03:32 PM
Page generated in 0.05928 seconds (64.21% PHP - 35.79% MySQL) with 11 queries
