12AU7/12AT7/12AX7 preamp schmatic needed
Old 3rd January 2009, 04:42 AM   #1
Sal Brisindi is offline Sal Brisindi  United States
Sal Brisindi's Avatar
Default 12AU7/12AT7/12AX7 preamp schmatic needed
Hi all,
I am currently rebuilding a Magnavox console 6BQ5 Push-Pull stereo amplifier. I am plugging my mp3 player into the RCA jacks but I don't have enough gain to use the amp to its full potential.
The chassis just so happens to have an extra hole drilled next to the 6EU7 tubes for which I installed a 9 pin socket. I want to build 1 extra stage of preamp connected into each channel.
Right now I am thinking using a 6N1P tube and copying the line stage amp that is based on Mikael Abdellah's SE KT88 amp. One triode of the 6N1P preamp will go to the left channel, and the other to the right.
I have many 12at7/u7and x7 tubes and I would like to use them as the filament current is 300ma vs 600ma for the 6N1P.
The B+ in the amp is approx 350vdc.
Anyone have a schematic up their sleeve? I am posting Mikael's schematic to give you an idea what I am thinking of using. Doing a search on the net, Mikael preamp stage is pretty generic as far as preamp stages go. I am breadboarding the preamp now to see if I can come up with something using a 12a(t.u.x)7 tube .
Thanks,
Sal
Old 3rd January 2009, 05:50 AM   #2
Eli Duttman is offline Eli Duttman  United States
Sal,
What does the OEM circuitry look like? The 6EU7 contains the same triode as the 12AX7. If you CCS load those triodes, you should get a stage gain of nearly 100X. 12AU7s make acceptable "concertina" phase splitters. For a variety of reasons, the 'X7 triode is a poor choice for splitter duty.
BTW, how was Xmas? Happy New Year!
Eli D.
Old 3rd January 2009, 11:01 AM   #3
roggom is offline roggom  United States
I just built one using a 6n2p (instead of the 6EU7) and it is great. It works best if you build the feedback circuit as well. Full credit to the author whomever it is.
Old 3rd January 2009, 02:05 PM   #4
Eli,
My Christmas and New Years were excellent, thanks.
Attached is the schematic of the Magnavox amp I am rebuilding. I just need a little more gain and I would like to stick with passive components in this application.
Thanks,
Sal
Old 3rd January 2009, 04:44 PM   #5
Thanks to a competent power trafo, this is fairly easy. The bottle count will not increase. Switch to 6U8s, as used by Scott, for the small signal circuitry. Scott/Fisher/Dyna style circuitry of a voltage gain block DC coupled to a "concertina" phase splitter works WELL, with "12" W. O/P tube types. As properly matched pairs of EL84s are easier to acquire than good quads, use a separate RC bias network in each channel.
Simplify, simplify, simplify! Use a red LED for pentode voltage gain block bias. Peak HF gain by loading the voltage gain block with an inductive wire wound resistor. A 10 Ohm resistor connects the LED to ground. A 100 Ohm resistor connects the "hot" speaker terminal to the LED/10 Ohm resistor junction. Approx. 9% of the O/P voltage is fed back. Short the NFB loop out at ultrasonic frequencies by connecting the "hot" speaker terminal to ground via a 15 nF. capacitor.
Protect the O/P trafo cores against saturation by rolling infrasonic noise off at the amp's I/Ps. 100 KOhms as the I/P grid leak resistor is quite ample. Parallel a 68 nF. cap. and a 15 nF. cap. and use the pair (instead of wire) to connect a RCA jack's center pin to the 100 KOhm grid leak part. F3 for the setup is roughly 19.2 Hz.
You can increase the B+ rail voltage by inserting a 5AR4 as the rectifier. Don't forget to move the B+ take off point to socket pin 8.
Eli D.
Old 4th January 2009, 01:47 AM   #6
Thanks for the info Eli, I knew you would keep it simple... lol
You probably forgot today more than I will ever know about the design aspect of tube amps...
Well, I prototyped a 12AT7 preamp on a breadboard.. took about 45 minutes to wire it up.
Here it is:
I must say it sounds pretty gosh darn good if I do say so myself!
B+ and filament power coming from the Magnavox amp.
Here is the whole temporary setup while I test it. Disregard the tube behind the RCA jacks on the amp, its not connected yet, that is where I want to put the 12AT7 tube.
Sal
Old 17th October 2009, 04:48 AM   #7
pboser is offline pboser  United States
Sal,
Do you have a schematic or verbal description of the circuit for your 12AT7 stage?
Thanks,
Pete
12AU7/12AT7/12AX7 preamp schmatic neededHide this!Advertise here!
Old big/long plate 12AX7's & 12AT7's thoriated Tubes / Valves 31 3rd July 2009 04:07 PM
12AT7 vs 12AU7 (interchangeable?) jn2630 Tubes / Valves 5 12th January 2008 05:34 AM
12AX7 and 12AT7 numerical data cs Tubes / Valves 4 24th June 2005 07:49 PM
12AU7 or 12AT7 instead of 12AX7 ? Gubby Tubes / Valves 5 26th June 2004 12:31 AM
Lower Distortion Alternatives to 12AT7 & 12AU7 ? DrDeville Tubes / Valves 19 20th May 2004 11:45 PM
