Preamp schematic... - diyAudio
Old 10th April 2003, 01:19 AM   #1
Guiness is offline Guiness  United States
Guiness's Avatar
Default Preamp schematic...
What do you guyz think? I nice little preamp using the WE407A. The schematic came from Gark K. Anyway the power supply is mine. I had the power transformer with double 6.3V 1A rectifier filaments. So why not double rectifier for a little gain in power.
Guiness
Old 10th April 2003, 01:20 AM   #2
Guiness's Avatar
And the power supply
Old 10th April 2003, 01:21 AM   #3
Sch3mat1c's Avatar
Send a message via ICQ to Sch3mat1c Send a message via AIM to Sch3mat1c
Circuit looks fine to me, I guess the 407 works a bit like a 12AU7 eh? (Darnit why am I always comparing tubes to the AU. LOL)
I don't get the 1k on the output though.
PS schem?
Edit:
Ah, there it is What diodes are those? 6X5?? Can't read the chokes well either.
Tim
Seven Transistor Labs, LLC
Projects and Resources / Electronic Design and Consultation
Old 10th April 2003, 01:50 AM   #4
Colt45 is offline Colt45  Serbia
Send a message via ICQ to Colt45
6X5's arent directly heated. you can use the same filament supply for them as for everything else
Old 10th April 2003, 02:18 PM   #5
...You have what looks like a 10uf cap at the top of the first triode's anode 22k resistor connecting to HT+, and this looks like it connects across the last 50uf cap in the power supply.
Is this because the pre-amp is remote from the power supply and you need the 10uf cap to prevent instability, or is there a decoupling resistor missing for the circuit diagram?
Old 10th April 2003, 03:13 PM   #6
Joel is offline Joel  United States
Joel's Avatar
Just two suggestions: remove the .47uF cap from the input - it's unnecessary. Also, two 6X5's for a preamp circuit is overkill. Why waste electricity?
I can't read the choke values, but I assume they are at least 10-15 henries? Then the cap values are good.
Joel
Old 10th April 2003, 05:41 PM   #7
Account Disabled
Hi, the tube for rectifier if use 80, EZ80 or we417a will better than 6X5.
I don't know why, but this my test result.
thanks
Thomas
www.diyaudiocraft.com
Old 10th April 2003, 05:48 PM   #8
Joel's Avatar
Thomas, what do you mean by "better"?
Old 10th April 2003, 05:57 PM   #9
Account Disabled
hi joel,
I put the same pre-amp which can use several types of rectifier tubes.
Test them in one set which we feel that it had a quiet good tone Balance.
Then use several disk & blind test to get the result.
Do U feel that is it fair for test.
any advise.
thanks
Thomas
Old 10th April 2003, 05:58 PM   #10
Account Disabled
Hi joel,
its we412a, not 417a, sorry fpr the mistake.
thanks
Thomas
Preamp schematic. beppe61 Solid State 49 23rd December 2015 09:16 PM
Looking for schematic of 26 WOT Preamp lanew Tubes / Valves 4 8th April 2009 05:40 AM
Need help to check out this preamp schematic. pchw Tubes / Valves 7 27th December 2007 08:47 PM
look for schematic of 12v preamp ??? prorms Tubes / Valves 2 25th October 2007 08:33 PM
Looking for Schematic using KC3 Preamp ? calico88 Tubes / Valves 0 3rd July 2006 05:00 AM
Copyright 1999-2017 diyAudio
