The schematic and build details are listed on his site. What sort of info do you seek?
http://boozhoundlabs.com/transformer-output-pre/
Yes, according to the author, the Edcor transformer is not shielded and hummed too much. Another recommendation is to use a larger chassis and place the output transformers on the opposite side from the power transformer.burnedfingers said:So the 15095 ALtec is being used in place of the Edcor?
losacco said:Well I think I might try this as my first build, looks simple. What kinda power supply?
Do a forum search for typical 6SN7 operation points. Here's a couple of threads:
Optimal operating point for 7N7/6SN7
http://www.diyaudio.com/forums/showthread.php?s=&threadid=134862&highlight=
http://www.diyaudio.com/forums/showthread.php?s=&threadid=119896&highlight=
http://www.diyaudio.com/forums/showthread.php?s=&threadid=66260&highlight=
If you cannot get the power supply voltage right on for the desired operating point, I recommend you substitute the 100K plate resistor by a CCS, like an IXYS, which will give you more latitude with the B+ and allow you to control the current.
Enjoy,
-- josé k.
Conceptually I am a fan of this sort of preamp, but there are some real issues with the implementation. The coupling cap is too small by almost an order of magnitude. Moreover, the unbypassed Rk increases ra by way too much -- could be why the cap used is doable, but either bypassing Rk, using an LED, or tying the OPT to the cathode rather than ground might be helpful. I also like a CCS on the plate here.
dsavitsk said:Conceptually I am a fan of this sort of preamp, but there are some real issues with the implementation. The coupling cap is too small by almost an order of magnitude. Moreover, the unbypassed Rk increases ra by way too much -- could be why the cap used is doable, but either bypassing Rk, using an LED, or tying the OPT to the cathode rather than ground might be helpful. I also like a CCS on the plate here.
Yes, with the following op points one could easily use a cheap 2V red LED for cathode biasing and a CCS set for 6.5mA:
Ups =230v
Up= 107v
Ip=6.5mA
Ug=-2v
Rpl=18kOm
Additionally, one could use two 6J5 or 2C22 in place of the 6SN7. Even two 76 tubes could replace the 6SN7, albeit, with different sonics.
Time to experiment...
Enjoy,
-- josé k.
- Tubes / Valves
- Booz preamp
