| diyAudio Sponsor | ||
I recall either SY or Eli recommending 6C45 for phono preamp use. It is an interesting tube for sure according to the preliminary research that I have done. I am not sure that I want to try to build with it in the near future as I do not have a scope handy but if one did would it make sense to use the 6C45 only in the input stages and use more pedestrian tubes such as 6N1P and or 12AY7 for the following stages? Probable topology would be three stages with 1/2 of the passive RIAA in between each stage.
How about LED bias for the 6C45? Any advantages or gotchas in that kind of bias with a hot tube like that? mike
mike - www.keepingsundayspecial.org |
#2 |
Probably Eli. I've had little experience with it other than some benchtop measurements as a cathode follower, where it performed very well. On paper, the specs look pretty good for phono use, but the D3a (which I use) looks even better- higher mu, lower equivalent noise resistance, and it can be run at lower currents (I use 20mA in the first stage).
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache |
#3 |
I've commented about the 6С45П (like the 5842) being "an in box oscillator", but I've never discussed using it in a phono preamp.
Rozenblit uses cascoded sets of the 6С45П as the 1st gain block is his phono stage design. FWIW, I think that the 6GK5 will do all that's necessary in the 1st gain block of a phono preamp, with far fewer headaches than "firecracker" triodes cause.
Eli D. |
#4 |
Thanks Eli. Other than not being a current production tube it looks quite nice. Good price too.
mike
| Best Sounding Phono Input Tube | tubewade | Tubes / Valves | 48 | 4th January 2008 12:46 AM |
| Using phono input with PLLXO | mashaffer | Subwoofers | 0 | 13th August 2007 11:36 PM |
| Phono input advice required | Satboy | Analogue Source | 3 | 24th February 2007 05:02 AM |
| Phono Pre-Design Input | philipbarrett | Tubes / Valves | 22 | 5th November 2005 04:20 PM |
| 6C45 in a phono amp? looks like this might be hot. | MIKET | Tubes / Valves | 0 | 23rd March 2004 09:51 AM |
| Page generated in 0.07962 seconds (81.53% PHP - 18.47% MySQL) with 10 queries |
