| diyAudio Sponsor | ||
Has anybody tried this circuit:
http://diyparadise.com/web/index.php...d=135&Itemid=5 I have not seen this on any tubeamp yet, what are the pros and cons? Happy new year! |
#2 |
frugal-phile(tm)
One of the cons is that with the output stage as phase splitter, you limit yourself to about 1/2 the power you get with a "normal" phase splitter.
There is a discussion of this circuit elsewhere on the forum, precipitating from a magazine article reproduced on someone's site (IIRC one of the US tube or transformer sippliers) dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#3 |
This gyy measures 10W output with 0.6% distorsion....I don't think it is half of normal.....it is like the Baby Huey?
Can't seem to find that discussion? |
#4 |
i think it is a push-pull design that runs in class a (most of the time) .10w output should be able.
greetings......... |
#5 | |
I would like to see that discussion also. Cheers
DIY Audio Projects [ 10" DIY Subwoofer | FE127E Sealed Bipole | [ LM3886 Chip Amp / Gainclone | K-12M Tube Amp Kit ] |
#6 |
I don't see it as hobbled to 1/2 whatever normal class A
power output would have been... Certainly it needs twice the drive signal voltage swing to achieve the same output. No big deal, that swing is still only a small fraction of B+. These sort self splitters are limited to class A operations. Once the driven side cuts off, it can't pass any information to the cathode of the opposing device to fill in the other half of the waveform. Class AB simply ain't gonna work. A2 is also right out. Bleeds grid current pollution onto the shared cathode node that make it impossible to split the music signal with accuracy. But as long as Class A is all you care about, I don't think this circuit any less powerful than "normal". Should have characteristic distortion half single Ended, half PushPull. Its never going to be in perfect cancellation of the 2nd harmonic, which is fine by me. Antitriode is a slightly more evolved scheme that might be worth looking into. If you like this sort of thing.... |
#7 | |
frugal-phile(tm)
Here are the other threads i was mentioning earlier. Very simple P-P output stage...will it work? modifications to compact EL84 amp You might also want to search on Audio Asylum for John Swenson's variation dave
#8 |
i think heatdisspation is often the limitation to class a outputpower;
in push-pull-designs(ab and a) there is nearly no limitation of the outputcurrent(equal outputpower?),but in single ended there is it i think ................. regards............ |
#9 |
Skorpio, I tried Bruce's implementation of the output section on a Chinese 6L6GC push-pull amp and it immediately sounded better, wider frequency range and more clarity. Maybe the CCS helps too. Then I drove it straight from the output of the first input valve (6N2 with both halves in parallel) instead of from one half of the LTP phase splitter, this gave more detail from the music. So now I have 2 x 6N1's just sitting there, heaters glowing but no power on the plates...
So as long as you use the CCS and don't mind class A operation only, I think its a great circuit and doesn't seem to compromise sound quality at all, in my case it was a definite improvement. Less components and better sound... Thanks for the class A explanation kenpeter, easy to understand. |
#10 |
Easy to understand??? Never been accused of that before! Must be slipping...
| 12AT7 and the Simple EL84 | haziz | Tubes / Valves | 75 | 11th September 2007 10:32 PM |
| Yeo's Simple EL84 with a twist | sorenj07 | Tubes / Valves | 19 | 18th October 2006 09:48 PM |
| Simple EL84 | Mas Penk | Tubes / Valves | 25 | 17th August 2006 01:55 AM |
| newb needs help on simple el84 amp PS | DJNUBZ | Tubes / Valves | 28 | 16th December 2005 05:47 PM |
| anyone tried the diy paradise simple el84 pp | RockysDad | Tubes / Valves | 6 | 11th April 2005 04:19 AM |
| Page generated in 0.10305 seconds (83.43% PHP - 16.57% MySQL) with 11 queries |
