Wiring Filaments with Center Tapped Secondaries
Old 27th March 2005, 12:34 PM   #21
Kofi Annan is offline Kofi Annan  United States
Kofi Annan's Avatar
Default DC Filament Wiring
Nothing like resurrecting an old post...
I have but one question:
How should I wire the filaments of an ECC83 and ECC88 when I have a regulated 6.3V filament supply? Here's what I'm thinking (which guarantees that its wrong):
Pin 4 (f): +6.3VDC
Pin 5 (f): PSU Ground
Pin 9 (ground): PSU Ground
I've only used AC on the filaments before, so I'm confused about this (obviously).
HHHEEEEEELLLLPPPP!!!!
Thanks,
Kofi
Old 27th March 2005, 04:31 PM   #22
Tekko is offline Tekko
Banned
WRONG! Shoud be pin 4 and pin 5 to 6.3v and pin 9 to ground, otherwise only one filament will be lit.
Old 20th March 2009, 08:24 PM   #23
MBMerlot is offline MBMerlot  United States
Send a message via MSN to MBMerlot
You always make sure that the potential like between your cathode and filaments are near equal.
Wiring Filaments with Center Tapped SecondariesHide this!Advertise here!
Transformer wiring question, series, parallel and center tapped swin1 Power Supplies 12 7th November 2008 07:58 PM
Center tapped transformer help Buzzy Parts 2 8th August 2008 09:35 AM
WTB 2:1 center tapped trafo in the UK MikeHunt79 Swap Meet 0 15th January 2008 01:46 AM
Wiring Toroid 14V non center tapped for PSU civilmonkey Chip Amps 7 23rd September 2006 08:12 PM
Center Tap vs Dual Secondaries StalfoS Chip Amps 6 18th March 2005 10:10 PM
