diyAudio Sponsor
Old 29th December 2008, 04:22 PM   #1
bigwill is offline bigwill  United Kingdom
Default Observations of amplifier sound
This is how I've perceived the following types of amplifiers, I'm wondering if anyone hears the same thing as me...
High FB Class-AB solid state amplifiers:
Sound fine at first, you wonder why you bother with valve amps. Things sound as they should, nothing sounds distorted. Then you hit some sibilance from a singer or loud cymbals and your ears burn off.
Sibilance sounds like harsh, bright white noise. Things with less extreme white noise content such as a singers breathing have a strange "edge"
Treble extension seems to be good
Bass is tight but slightly lean depending on the speaker, obviously due to the high damping
High FB tube amps:
Sound good, but try to minimize clipping. Sibilance is much less unpleasant than the SS amp. Sibilance is rendered nowhere near as harshly, but it still seems to briefly drown everything else out with a darker "ssss". The amp is still enjoyable to listen to.
Bass good but not quite as damped as with the SS amp, but is pleasing.
No FB tube amps:
Treble actually sounds rolled off at first, but this is easy to adjust to. It's just different. Things like reverb and echo suddenly become apparent in recordings you've heard hundreds of times, it's somewhat unnerving, you can actually hear further "down"
Sibilance is much improved, doesn't seem to send the amp into a strange "overload" condition (I know it's not literally like any kind of overload but it's the best I can articulate it)
Bass will be less damped but this can be overcome with speakers with this in mind
Old 29th December 2008, 05:46 PM   #2
Michael Koster's Avatar
--- Things like reverb and echo suddenly become apparent in recordings you've heard hundreds of times, it's somewhat unnerving, you can actually hear further "down" ---
This is the main reason I'm switching to a tube amp + high eff speaker
system for my recording studio monitor system. It's sometimes called
"resolving power" as if it's some kind of microscope, which it does
seem to be relative to my current SS Haflers and 86db speakers.
I'm convinced that this can be measured as follows, with music as
a test signal, using some subtractive techniques. Take 2 identical
amps and combine the outputs in opposite polarity. Null these using
sine waves and a notch filter. Music program should also null out.
Now do the same with 2 different amps you want to compare. On the
music signal, any differences in response will appear at the "A minus B"
output.
Michael
Old 29th December 2008, 06:48 PM   #3
I like your "observations" bigwill, very intersting!
I tend to agree at all. This is the reason because I think multiamp
can be the "solution"
Very radical but it works IMO
Paolo
Old 29th December 2008, 07:30 PM   #4
rdf is offline rdf  Canada
rdf's Avatar
Don't disagree with the general observations but it's still odd considering that, in light of the rising high frequency impedance of most speakers, NoFB tube amps should sound brightest due to the high Zout.
Ears aren't microphones.
Old 29th December 2008, 08:00 PM   #5
analog_sa's Avatar
These observations are really stereotypes and simplifications. If all three amps are built to an equally poor standard and very limited music samples are used i would agree with the conclusions.
Sibilance and harshness with NFB SS amps? The good ones have been free of these afflictions for many years. As far as ambience, microdynamics, image palpability and tone go, yes, NFB free tube amps really rule. But it's not all peaches and cream. How many of that breed can take a full orchestra and not fall apart in the crescendos?
Old 30th December 2008, 12:18 PM   #6
analog_sa ,
please can you post some "names" ( commercial brands) of overall feedback solid state amps that ,in your experience, sound extremelly good ?
Cheers ,
Paolo
Observations of FE127 VS. FE126 VS. FE103 and different enclosures Harderror Full Range 11 24th February 2012 02:00 PM
Transistor HFE observations. Zero Cool Solid State 35 26th December 2006 10:10 AM
Fostex 103e Observations kaybee Full Range 10 10th November 2006 11:36 AM
TDA1543 DAC issues and observations. IpsilonSound Digital Source 16 2nd July 2004 03:38 AM
TT cartridge observations bart_dood Analogue Source 6 10th December 2003 02:06 PM
Page generated in 0.09075 seconds (76.07% PHP - 23.93% MySQL) with 10 queries
