Exact RIAA numbers?
Exact RIAA numbers?
Old 11th April 2003, 10:12 AM   #21
EC8010 is offline EC8010  United Kingdom
diyAudio Moderator Emeritus
EC8010's Avatar
Default Accuracy
My numbers were generated from two different forms of the RIAA equation. First form was the (1 + sT) form using complex numbers, which was manipulated into a form that Lotus123 could use. Second form was the form where each time constant has a logarithmic term, and these are summed. The two forms were then compared for accuracy, and agreed to 5dp (dBs).
Further, the equations for the complex form were checked in a program written in QBASIC, and the results agreed with the spreadsheet.
The only common factor remaining is the computer itself...
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference...
Old 11th April 2003, 02:54 PM   #22
Jocko Homo is offline Jocko Homo  United States
Banned
Default The hump......
It is there, and you would probably benefit by using accurate equipment. Im' lucky enough to have such a setup.
Granted, 0.25 dB is not much, but when spread out over an ocatve, it is easily heard.
Jocko
Old 11th April 2003, 10:55 PM   #23
fdegrove is offline fdegrove  Europe
diyAudio Senior Member
fdegrove's Avatar
Default RIAA AND NICE INVITES.
Come on up ... my end of Canada is closer to California thou.
Thank you so much and of course the same welcome to you whenever you might come to Europe.
Purrrcelisely, and that's exactly why RIAA accuracy matters IMO.
Frank
Old 11th April 2003, 11:09 PM   #24
EC8010's Avatar
Default Shelf errors
Perzackly. RIAA errors produce shelf errors, and the audible effect of a shelf error is way out of proportion to the measured error. Perhaps it's a power thing? (Active crossovers are especially critical of level errors between drivers.) Worse, it's really hard getting RIAA errors down.
Exact RIAA numbers?Hide this!Advertise here!
Exact E12D/SPL Telstar Full Range 2 3rd April 2009 11:49 AM
exact dimensions of a BIB fe167e AudioGeek Full Range 15 21st January 2007 10:40 PM
Exact dimensions for BiB with 40-1354? Spasticteapot Full Range 1 24th November 2006 10:22 PM
Completed Exact Speakers BTW Full Range 22 30th April 2006 03:21 PM
search exact phrase jcx Forum Problems 2 13th September 2005 02:48 PM
Copyright ©1999-2017 diyAudio
