diyAudio Sponsor
Old 28th December 2008, 06:50 AM   #1
Sunsun22's Avatar
Default Is 6V DC too low for heater filament?
I am trying to use 7806 as regulator for my tube preamp. Is 6V DC too low? What is the disadvantages of using a lower voltage for filament?
Old 28th December 2008, 07:08 AM   #2
ericj is offline ericj  United States
ericj's Avatar
it will work as 6.0v is still within tolerances.
however, we should ask, why do you want to do this?
If you have 6.3vac available, twist the wires tightly and use AC heaters. properly installed AC heat isn't noisy and increases the lifespan of the filament.
if you have only DC available, sometimes you can get better performance by using an lm317 configured as a current source.
even if was sure i wanted voltage regulated heaters, i find that an lm317t is more durable and performs better than a 78 series fixed regulator, so i just use those instead. it helps that i have a large assortment of resistors on hand to come up with the resistor networks for the 317, i admit.
Old 28th December 2008, 07:25 AM   #3
ja2dhc is offline ja2dhc  Japan
Send a message via AIM to ja2dhc Send a message via MSN to ja2dhc Send a message via Yahoo to ja2dhc
Default Re: Is 6V DC too low for heater filament?
The specs of most of In-Direct heating tubes specify +/- 10%
for voltage tolerance and therefore DC 6V is within spec while
Direct heating' are +/- 5% as is the lower limit if DC6V is used.
A far as I experienced, the lower voltage within the spec effects
good sonic. So I usually apply AC 6V for In-Direct tubes.
Old 28th December 2008, 08:18 AM   #4
dsavitsk's Avatar
Probably not, but if you are concerned, put a diode that drops 0.3V between the ground pin of the regulator and ground.
http://www.ecpaudio.com
Old 29th December 2008, 04:03 AM   #5
It would take a miracle for me to find the relevant article that appeared in either GlassAudio or AudioExpress, but I believe some theorizing took place showing actual improvements in running low filament voltage. I believe there was lower distortion. And as I recall the voltage was significantly lower than design center. Try googling...
Wish I'd studied this stuff with as much interest 30 years ago!
Old 29th December 2008, 04:06 AM   #6
Sunsun22's Avatar
I searched Mouser but it seems there is no diode that can have a drop of 0.3V. Do you have anything in mind?
Old 29th December 2008, 04:59 AM   #7
dsavitsk's Avatar
It was on Steve Bench's site. The original site is gone, but it is mirrored at http://greygum.net/sbench/sbench101/
IIRC, this is more with DH than IDH tubes.
You're probably right. How about a 5V reg with a 1.3V diode
Old 29th December 2008, 07:18 AM   #8
Heater voltages affect tube lifetime quite a bit, and noise as well.
Some designs (e.g. Dynaco phono pre, Neumann U47 mic) lower the voltage to decrease noise (and grid current).
Linearity is affected to differing degrees, depending on cathode construction and emission reserve.
Teddy (Tetsu Kimura) did some research years ago on a few popular tubes.
The page is in Japanese, but the graphs speak for themselves.
http://www2.famille.ne.jp/~teddy/datalib/heater.htm
Old 29th December 2008, 07:45 AM   #9
Sunsun22's Avatar
Dear all,
Thank you for the inputs. I think I am feeling easy now to use 6V. I am just lazy to save two resistors by not using 317.
Cheers.
12AX7 heater filament resistance Ipanema Tubes / Valves 25 2nd July 2009 06:12 PM
Parallel vs. series filament supply - or another filament idea engels Tubes / Valves 11 13th May 2007 01:06 PM
5687 filament heater question dr._sleep Tubes / Valves 2 25th August 2005 03:45 AM
Troubl-shooting heater voltage for filament andy2 Tubes / Valves 12 10th January 2005 04:41 PM
grounding heater/filament center metebalci Tubes / Valves 6 27th March 2004 08:24 AM
Page generated in 0.09704 seconds (80.49% PHP - 19.51% MySQL) with 10 queries
