| diyAudio Sponsor | ||
I have the need to run eight KT88s in parallel push pull and I need a driver transformer that'll do the job. I have a nice 6000 / 6000ct 1:1 20W Collins modulation transformer, would it do the job? I don't know how modulation transformers differ from driver transformers.
I have also been looking at the Sowter 8423. Oh yes, I'm powering the transformer with a 6L6. Ideas? Recommendations? Thanks! |
#2 |
My guess is that a mod tranny secondary =may= be built to tolerate the full DC current of the final RF stage it is modulating, seeing that the secondary often goes in series with the DC supply to the final. If this is the case the tranny will probably have a gapped core like a normal single ended class A tranny does.
http://en.wikipedia.org/wiki/File:Ammodstage.png
Best-ever T/S parameter spreadsheet. http://www.diyaudio.com/forums/multi...tml#post353269 |
#3 | |
"...we stumble and get up, we are sad, confident, insecure, feel loneliness and joy and love. There is nothing more; but I want nothing more.” - Christopher Hitchens 1949-2011 |
#4 |
Not sure about the Collins, but, many mod xfrms are spec. for bandwidth of voice only, FWIW (for example 300hz-6K).
Be sure your foil hat has a good low impedance ground. |
#5 | |
http://ampwares.com/schematics/400ps.pdf Re: the Collins's frequency response, it's rated 200-5Khz. But I tested it and its flat from 20-20Khz. But perhaps seeing as how the Sowter is a real driver transformer, I should use it.... |
#6 |
Piece of cake. It's a pentode input, so the total capacitance will be pretty low. If it's being run in AB2, you can use power MOSFETs as source followers to drive the grids, then do the voltage amplification with a plain vanilla diff amp (6SN7 is classic for that function). This will work better than a driver transformer and cost you a fraction of what the Sowter does. If it's AB1, you probably don't even need the MOSFETs, though they'll speed the overload recovery and extend the bandwidth a bit.
In this circuit, they're using the transformer to go from single-ended to balanced, which is much better done at lower levels.
#7 |
Well, I have already ordered the Sowter so perhaps I should stick with the driver transformer approach...
| gate driver transformer setup | zilog | Power Supplies | 10 | 11th April 2008 06:33 AM |
| Gibson reverb driver transformer | garydue | Tubes / Valves | 5 | 15th September 2007 12:02 AM |
| RQ: Methods for calculate driver transformer? | Yassen | Solid State | 1 | 9th May 2007 09:59 AM |
| Questions on 1:1:1 driver transformer | bst | Tubes / Valves | 4 | 25th June 2006 09:36 AM |
| Help with driver transformer | Original Burnedfingers | Tubes / Valves | 0 | 27th October 2004 12:59 PM |
| Page generated in 0.09830 seconds (78.94% PHP - 21.06% MySQL) with 10 queries |
