need manual for heathkit sp2
Old 28th December 2008, 12:45 AM   #1
jrclark1 is offline jrclark1  United States
Default need manual for heathkit sp2
Help
I have heathkit sp2 pre ,I have no sound from output to amp on either channel and yet tape out works plugging into receiver, I have no manual and am looking for one and advise , I replaced all caps in p/s and am waiting for coupling caps ,would greatly appreciate any help offered
Thanks John
Old 30th December 2008, 01:50 AM   #2
VictoriaGuy is offline VictoriaGuy  Canada
John-
A few things you didn't mention, but have probably checked already:
-Have you downloaded the schematic? There's a good pdf available (free) online and a gif as well.
-Are the tubes good?
-Have you checked voltages at the tubes and in the power supply?
-Have you used contact cleaner on the input selector switch?
I don't know how much you've worked on tube circuits, but it sounds like you know what you are doing with a soldering iron. Do be careful- I find that it is often better to clip the test leads to the test points rather than risk having the probe slip. Definitely clip the COM lead to ground and only use one hand to work the +probe. There are good safety hints in a thread at the top of the 'Tubes' section here.
Next step would be to rig up a signal tracer. The SP2 is not a very complicated circuit, so you will be successful.
Cheers
John
need manual for heathkit sp2Hide this!Advertise here!
Seek help: Leader LDM-171 user manual (Service Manual) 0451ym Parts 1 21st November 2013 04:10 PM
Heathkit IT-17 operation manual & Schematic redwine1118 Swap Meet 22 20th June 2011 11:45 PM
Heathkit Manual ke4vbg Tubes / Valves 2 20th July 2008 02:04 PM
Manual for Heathkit AA-121 Power Amp CR007 Tubes / Valves 3 24th June 2008 04:11 PM
Heathkit TT-1A lpd Swap Meet 0 21st November 2003 06:01 AM
