diyAudio Sponsor
Old 31st December 2008, 02:58 PM   #11
kevinkr's Avatar
Originally posted by HollowState
You haven't mentioned what "type" of resistor(s) burned. If they were film resistors these have very little tolerance for overloads, even momentary. Film resistors act like fuses when overloaded. Especially metal film types. That's why they're call flameproof resistors. For screen resistors this is a good place for carbon composition types like Allen Bradley. They can smoke and still continue to function. If you're burning out 5 watt wire wounds, then it's probably a result of todays imported garbage tubes.
Just to dispel a misconception in the previous post, not all metal oxide or metal film resistors are flameproof. You must purchase ones that are specifically specified as being flame proof.. I have seen more than a couple of metal film types burn, although I have yet to see any metal oxide types burn IIRC...
Carbon composition and carbon film types burn like crazy, (direct personal experience - BIG, SMOKY FIRE!) while the CC types are very overload tolerant the CF types are not. I would not use them in any application where there is a possibility of an overload situation that could result in extended overheating. In such a case I would use a flameproof fusible resistor. (Digikey, Mouser, etc.)
www.kta-hifi.net
Old 31st December 2008, 07:02 PM   #12
It was a 1 watt, 470 ohm metal film resistor. There were no flames, but it did turn dark brown and leave a brown burn spot in the PCB. My only guess is that it must've been a bad tube; I had just changed to a new set of tubes before the problems started, so I'll have them checked. Does moving up to a 5 watt resistor help at all, btw?
Thanks!
Old 31st December 2008, 10:01 PM   #13
kevinkr's Avatar
Using a 5W resistor should reduce the incidence of this sort of failure - no reason not to imo..
www.kta-hifi.net
Changing grid leak bias preamp to cathode bias bereanbill Tubes / Valves 8 28th March 2009 05:26 PM
Finding bias point in PP fixed bias beamnet Tubes / Valves 14 7th December 2008 01:25 PM
Stray hum pickup *preamp* cathode R-bias vs. battery bias & 12AU7vs.5687 awedio Tubes / Valves 2 19th April 2008 01:30 AM
Battery grid bias to fixed bias in Toccato? w00t Tubes / Valves 3 2nd December 2007 12:34 AM
Supressed bias amplifier, automatic variable bias system. destroyer X Solid State 2 20th September 2004 10:24 AM
Page generated in 0.06107 seconds (81.03% PHP - 18.97% MySQL) with 10 queries
