| diyAudio Sponsor | ||
First of all, please excuse my ignorance in this subject, I'm completely inept with tubes! (more so then all other electronics at this point....)
I've order some of the Tube Buffered Gain Clones boards from Rhys over at the chipamp side of the forum and he calls for an ECC88 tube as the buffer. I'm looking on Tubeman.com for these tubes, and I get a lot of E88CC's instead. I've gathered that these are the "High Quality ECC88". So will the E88CCs work in an unaltered ECC88 circuit? Also, what other code names does the ECC88 go by? Thanks, Steve |
#2 |
6DJ8, 7308, and 6922 are a few others.
Craig |
#3 | |
E88CC = 6922 They all are the same except for the maximum ratings and filament currents. The E88CC will work in any circuit in place of the ECC88. The reverse is possible only within the maximum ratings. Cheers |
#4 |
Thank you for your help. I was unsure how that was all going to work out. I'll place my order on Monday! Any recommendations on specific manufactures? JJ, Electro-Harmonix, JAN, Tesla ?
Thanks, steve |
#5 |
6H23P
#6 |
6N23P. In russian it becomes 6Н23П.
#7 |
Also CCa double triodes specially selected premium E88CC for German post and specially intended for audio use!
| 20 x E88CC Telefunken | old_tube_master | Swap Meet | 5 | 8th January 2011 02:43 PM |
| ECC88 Help | rhysh | Tubes / Valves | 2 | 1st December 2008 10:52 PM |
| What to do with ECC88's? | Simpleton | Tubes / Valves | 15 | 16th June 2005 08:39 AM |
| OTL ECC88 amp | Tyimo | Tubes / Valves | 13 | 16th February 2005 04:40 PM |
| Page generated in 0.08747 seconds (80.67% PHP - 19.33% MySQL) with 10 queries |
