diyAudio Sponsor
Old 25th December 2008, 01:29 PM   #1
Question preamp question
Hello!
Im going to build something similar to this amp:
http://www.ax84.com/static/sel/AX84_SEL_080729.pdf
and I dont understand why would someone amplify a signal, and
then halve it with two 220K voltage divider.
Any ideas?
Merry Xmas,
Miha
Old 25th December 2008, 01:36 PM   #2
Frank Berry's Avatar
It's not a voltage divider ... It's a high frequency boost circuit.
That's the circuit after the first volume control. The second pair of resisters is a voltage divider. Only the designer knows why it's there.
Frank
Old 25th December 2008, 01:37 PM   #3
flg is offline flg  United States
flg's Avatar
There is also a cap there Mids and Highs are not attenuatted but the bottom end is cut 6db.
“Be who you are and say what you feel because those who mind don't matter and those who matter don't mind.” Dr. Seuss
Old 25th December 2008, 01:46 PM   #4
lineup is offline lineup  Sweden
lineup's Avatar
This is not unusual for Tube amplifiers.
When using 1 tube and signle end configuration. Same for amplifiers using one single JFET transistor.
In these cases there are reasons to try to find the optimal working condition for the single transistor/tube.
With biploar transistors, it is very common to use emitter resistors to reduce gain.
In the shematic is used no less than 3 tubes gain stages!
No wonder there is too much gain.
You are basically right.
As any voltage amplification is bound to degrade signal
we should not amplify more than we need + a bit extra margin.
Because more amplification will only add more distortion than what we want
lineup
Old 25th December 2008, 03:32 PM   #5
Wouldnt it be more logical to reduce the gain of the stage by lowering the plate resistance? Maybe there would be less distortion operating the tube with less plate swing, thus greater linearity, than first generating too much signal and then atteunating it..
Anyway this is a guitar amp, so more or less distortion is what one needs.
What about the loop around the cathode follower with the diode?
Whats that for?
Thanks!
Miha
Old 25th December 2008, 07:59 PM   #6
Miles Prower's Avatar
Whats that for?
Since this has a SS power supply, the positive rail will come up very fast, much faster than the heaters can warm up. They included that to prevent overvolting the grid of the second 12AX7, which can't stand positive grid voltages and grid current. Once the heaters are hot, the diode is reverse biased and drops out of the circuit (except for its junction capacitance, of course, but who cares? It's a gee-tah amp).
I took care of the problem of SS power supplies and DC coupled stages by making separate heater and HV supplies. Power up the heaters first, then turn on the HV, and you don't have to worry about it.
There are no foxes in atheistholes
www.dolphin-hsl.com
Old 28th December 2008, 09:59 AM   #7
But this amp does include separate switches for heaters and B+ ..
Old 28th December 2008, 05:49 PM   #8
Merlinb is offline Merlinb  United Kingdom
Default Re: preamp question
Hello!
Any ideas?
Merry Xmas,
Miha
The quality of overdrive generated in a valve is partly related the anode voltage. For a 'lead sound' it is desirable to use a large anode resistor, so the anode voltage swings low, which helps generate a 'hard' sound.
However, the output signal is too large to deliver directly to the next stage (particularly at low frequencies), so it's usual to include some sort of attenuation, which can also include treble boosting too.
The diode/resistor protects the cathode follower from arcing, which might occur if the standby switch is not used.
Uno preamp question john blackburn Chip Amps 14 15th February 2010 10:26 PM
preamp question sakis Solid State 4 17th July 2009 11:28 PM
Preamp Question! Lab_Rodent Solid State 9 5th December 2007 11:14 PM
X0 preamp question Tyimo Pass Labs 5 25th March 2007 08:32 AM
Preamp Question mapiao Tubes / Valves 0 6th February 2007 02:41 AM
Page generated in 0.10275 seconds (79.11% PHP - 20.89% MySQL) with 10 queries
