| diyAudio Sponsor | ||
#31 | |
Once you start listening you notice such "discrepancies" all the time. Still, i'm curious why you blame the CCS. I use a similar circuit with a single fet ccs and a Jung reg for the negative voltage and it sounds quite ok. Maybe your high voltage reg carries some of the blame. Or the passive parts. |
#32 | |
Then I changed into a different CCS topology, as used by Nelson, and all the high frequencies reappeared. But the sound still was unconvincing so if the ccs had such a dominant effect next was its power supply. Out with the LM337 and replaced it with a discrete, no feedback regulator and there was marked improvement. Initially I thought I cracked it, but further listening left me unimpressed. The low frequencies may be excellent and the soundstage very precise, but realism in mid to high frequencies is just not up to expectations. Transistor sound. With regards to passive components, resistors are all Dale RN-65 and capacitors low-inductance metalized polypropylene. There are no electrolytics anywhere but the filament voltage regulators. Maybe the 6H6Ps are just cr@p, so a pair of 6H30Ps is on its way. BAT and Conrad Johnson must know something about that! In the meantime, its back with the old nice and simple SE passive preamp.
'in acts and works bigger than a great wale's tail' |
#33 | |
Thanks for the explicit reply. My build also has some of the "transistor sound" although the bass is very nice indeed. |
#34 |
B@gger, it's back to SE!
| balanced tube preamp | Freddie | Tubes / Valves | 29 | 18th March 2010 10:50 AM |
| Tube Preamp Idea | mattthegamer463 | Tubes / Valves | 14 | 8th February 2009 01:56 AM |
| Balanced tube preamp for class D power amps. | jane | Tubes / Valves | 5 | 13th December 2006 08:41 AM |
| balanced stereo tube preamp for a recording studio | zdpinet | Tubes / Valves | 12 | 15th July 2002 04:53 PM |
| Page generated in 0.09700 seconds (73.76% PHP - 26.24% MySQL) with 11 queries |
