diyAudio Sponsor
Old 7th May 2009, 08:10 AM   #21
EC8010 is offline EC8010  United Kingdom
EC8010's Avatar
I'm not sure about your power supply. You've used a negative reference to avoid it having to be in the error amplifier's cathode, and that's a nice idea, but you haven't filtered the HF noise from the reference and the speed-up capacitor from the sampled HT looks rather large. You might want to have a more detailed think about those arrangements.
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference...
Old 7th May 2009, 11:03 AM   #22
Thanks EC8010, I have since revised the schematic in an attempt to play safer. This is what I have implemented on the pcb.
Loop gain will be reduced due to degeneration of the error amplifier, hence regulation will be poorer, but hopefully adequate for my widely fluctuating mains supply.
Old 8th May 2009, 02:54 PM   #23
EC8010's Avatar
Well, your new circuit will almost certainly work, but I liked your first idea. Surely you could have added neon filtering to the first idea?
Old 8th May 2009, 06:27 PM   #24
thanks EC8010, the idea is from a military electronics book my dad used to have, and yes, maybe I should have followed it....if only time for prototyping was available!
What is neon filtering?
Old 9th May 2009, 10:13 AM   #25
EC8010's Avatar
There's nothing complicated about neon filtering. You can't put large capacitors across neons (would make them oscillate), but you can take the neon voltage via an RC network into your (highish impedance) summing node. So, you might be able to get away with a 100k resistor from the neon, then add a 1uF to ground. That gives you a lot of filtering of neon noise.
Old 9th May 2009, 12:26 PM   #26
I was not aware of the terminology. Definitely, supplying the reference voltage to the high-Z control grid rather than the cathode permits this type of filtering. So apart from better regulation, lower noise would also be expected of the first topology; but how much better, I haven't a clue. And the second circuit is quite popular too.
Old 10th May 2009, 09:59 AM   #27
EC8010's Avatar
Noise from the reference is the major source of noise in a regulator. The second circuit is popular because it is cheap (oh, and lots of people know about it).
Old 8th June 2009, 03:34 PM   #28
Slowly getting together...
http://www.imageshack.gr/view.php?fi...8d9obtn9y0.gif
Old 15th June 2009, 02:29 PM   #29
Got the transformer and hooked it up last night - power dissipation is high, but on the bench (with signal generator and scope) all seems ok. What really surprised me though, is how quite the regulated 280V are. While I get about 10mVp-p from the filament's LM317 regulator, there is no more that 3mV of noise on the 280V. True there is the typical of tubes low-frequency wander, but its amplitude is less than 10mVp-p. All in all, this is an excellent tube regulator topology, so much that fancier circuits may not have much more to offer.
Old 19th July 2009, 07:22 PM   #30
Default Too much cascode is bad for your health
I see people are still interested in this thread. I have listened to the prototype for quite a while now and this is what I have to say:
Never mind the simulations or sonically unrelated technical justifications; BEWARE of cascode current sources, either BJT or mosfet, at least for long-tailed pairs. Would you believe that the thing measured f3dB 300KHz but sounded more like 5KHz?
Oh and do bear in mind that with LTPs you are listening to the current source and its power supply, not the amplifying devices themselves.
No wonder clever people are suspicious of the topology.
'in acts and works
bigger than a great wale's tail'
balanced tube preamp Freddie Tubes / Valves 29 18th March 2010 10:50 AM
Tube Preamp Idea mattthegamer463 Tubes / Valves 14 8th February 2009 01:56 AM
Balanced tube preamp for class D power amps. jane Tubes / Valves 5 13th December 2006 08:41 AM
balanced stereo tube preamp for a recording studio zdpinet Tubes / Valves 12 15th July 2002 04:53 PM
Page generated in 0.11949 seconds (79.57% PHP - 20.43% MySQL) with 11 queries
