| diyAudio Sponsor | ||
#11 |
Now getting closer - how about this?
#12 |
Why have all those expensive FETs down the bottom? The bipolar transistor rules OK. You might do better to hold the gate of the upper FET at a negative voltage so as to increase Vds and avoid some of the "tetrode" negative resistance problems sometimes seen at low Vds with high voltage FETs.
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference... |
#13 |
I already had a bunch of the K247s, so it is ok. Thanks about the point regarding the mosfet Vds; I have revised the schematic. Is the 4.7u capacitor wired correctly?
#14 |
I notice that the CMR follows a single-pole law, the pole located roughly at 30Hz, decreasing 20dB/dec thereafter. This is not very nice, is it?
#15 |
I'd ideally like to see more voltage across that upper FET and less across the lower. The lower ones only need 5V or so. The capacitor looks fine, but it doesn't need to be so big. FETs are high impedance devices - scale those resistors up by a factor of 20 and scale the capacitor down by a factor of 20.
#16 |
Will do, cheers. A smaller mosfet with less capacitance helps push the CMR 1st order pole up, so a IRF820 will help here.
I ordered the 6N6s too dirt cheap, so the design will be on its way soon. I need to get the regulated tube power supply design right, as the power supply rejection of the LTP is virtually nil. |
#17 | |
#18 |
The nice thing about this topology is that the mosfet may be ditched in favour of a bjt and vice-versa. The bjt seems to yield 1MOhm//15pF as opposed to 15M//100p of the mosfet. I guess it is wait until construction time to see which sounds best.
#19 |
With regards to the power supply, this is what I'm working on.
Line regulation is useful around here. I hope I'm not boring people by re-inventing the wheel... |
#20 |
Got the pcb today...relay volume control, balanced signal path, regulated ps etc
| balanced tube preamp | Freddie | Tubes / Valves | 29 | 18th March 2010 10:50 AM |
| Tube Preamp Idea | mattthegamer463 | Tubes / Valves | 14 | 8th February 2009 01:56 AM |
| Balanced tube preamp for class D power amps. | jane | Tubes / Valves | 5 | 13th December 2006 08:41 AM |
| balanced stereo tube preamp for a recording studio | zdpinet | Tubes / Valves | 12 | 15th July 2002 04:53 PM |
| Page generated in 0.10972 seconds (76.46% PHP - 23.54% MySQL) with 11 queries |
