Old 29th December 2008, 09:46 PM   #11
Guytute is offline Guytute  United States
Thanks for the replies. So although I didn't get a stright yes or no answer, based on some of the responses I would imagine I would have no problem running parrallel out of the left and right speaker level of the tube amp and into both the bookshelfs and the speaker level in of the powered sub. I would imagine this would be my best bet as it would avoid the SW crossover.
If anyone can answer this specific question it would be great. Does hooking it up in the manner above have any effect on the load that the amp is seeing?
Old 29th December 2008, 10:54 PM   #12
There is no appreciable effect. The SW's crossover presents a relatively high impedance to the main amp, below the "corner" frequency. When impedances are connected in parallel, the lowest of the set tends to dominate, according to the Law that follows immediately.
1/Z NET = 1/Z1 + 1/Z2 ... + 1/Zn
If 8 Ohms and 80 Ohms are connected in parallel, the net is approx. 7.3 Ohms.
Eli D.
$120 battery powered tube amp on eBay?? ChopperCharles Tubes / Valves 41 2nd February 2010 03:27 PM
Zigmahornet with Tube powered Ipod Dock Jhovis Full Range 4 26th December 2008 02:35 AM
Leaving tube preamp always powered on. stoolpigeon Tubes / Valves 31 20th April 2007 07:59 PM
High Powered 3cx300a1 Tube Amp BlackUnikorn Tubes / Valves 22 21st June 2006 12:17 AM
Battery powered tube headphone amp mig-ru Headphone Systems 1 3rd February 2004 10:59 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
