Cathode Bypass caps - how to choose? - Page 2 - diyAudio
Old 23rd December 2008, 06:05 AM   #11
dsavitsk's Avatar
Originally posted by SY
The LEDs, besides being excellent voltage sources (and very quiet) also give a nice visual indication that current is running through the stage.
They also cost just a few pennies each, and they sound better than even the best electrolytic bypass.
Old 29th December 2008, 09:19 PM   #12
JesseG is offline JesseG  Canada
JesseG's Avatar
So, LED bias is as simple as putting a string of LEDs in series to get the desired voltage drop? No Caps?
Jess
"If we crashed our cars as often as we crashed our computers, we'd all be dead!"
Old 29th December 2008, 10:19 PM   #13
JesseG,
I've been quizzing the helpful folk here on exactly the same thing - read this:
LED cathode bias - how to pick LED?
Old 29th December 2008, 11:14 PM   #14
diyAudio Senior Member
fdegrove's Avatar
Even better than a thousand uF worth of filmcaps too...
Even twenty five years ago you'd replace electrolytic bypass caps on small signal tubes (2 to 6V drop across the cathode R) with solid tantulum caps or did away with them altogether and used alterantive methods for biasing the grid.
As for leds, you'd better stock up on the older ones. The newer brighter ones aren't all that great. (See EC8010's post on the topic of LED cathode bias, I only confirm his findings).
Frank
Old 30th December 2008, 01:17 AM   #15
SY's Avatar
Frank, as EC said, the new Agilent jobs are quite bright, but have excellent performance. I'm not as convinced as he is that "bright," "new," and "higher impedance" correlate. I've measured about a dozen different kinds of red LEDs and found high and low impedances in new ones, old one, bright ones, and dim ones.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 30th December 2008, 01:55 AM   #16
zapnspark's Avatar
How about my wildman approach to creating a completely isolated negative (or positive) bias voltage?
http://i114.photobucket.com/albums/n...rk/IsoBias.png
Cheers.
ZAPNSPARK
Old 20th December 2016, 12:13 PM   #17
Have any of you tried the newer solid polymer caps as cathode bypass caps.
They are cheap as dirt I think Digikey has some 470 16 v ones with a esr of
8 mili ohms for $1 each . I just wonder how they sound ?
cathode bypass caps suggestions please for newbie tmhajw Tubes / Valves 8 7th March 2008 09:19 PM
HELP! Cathode bypass caps keep going... aletheian Tubes / Valves 13 2nd August 2006 04:45 AM
Non-Polar caps to cathode bypass s2kov Tubes / Valves 4 13th September 2004 09:39 AM
Cathode bypass caps? SHiFTY Tubes / Valves 18 21st August 2002 08:27 PM
Cathode bypass cap ? woody Tubes / Valves 2 19th May 2002 06:53 AM
Copyright 1999-2017 diyAudio
