| diyAudio Sponsor | ||
I am building an Aikido line level pre. I have all of the componenents mounted to an aluminum toplate. When I power it up I can feel a slight vibration when I lightly brush against the plate with my finger. This must be from the Trannie. I have rubber mounted the trannie and I can still feel it. The aikido board is mounted on stand-offs and when i touch the tubes I don't feel the vibration. So is this something that will have an audible consequence? Also I only feel it if I'm brushing lightly. If I touch it with any pressure I don't feel anything.
#2 |
Are you sure it really is a vibration? I have felt very similar sensations with a light touch from ungrounded metal work. Your chassis should have a good direct ground through a third wire in the power cord. If not, give that a try.
"The supercomputer is technologically impossible. It would take all of the water that flows over Niagara Falls to cool the heat generated by the number of vacuum tubes required." ~ Professor of Electrical Engineering, New York University |
#3 |
That is a very good point the chassis is not grounded currently! I will try that and report back.
#4 |
That sensation gets worst the higher the voltage is. You should feel what it's like at 15kv, like a paint shaker LOL.
#5 |
Great troubleshooting! Grounded the chassis and everything is fine. There is some wonderful talent on this site.
| Capacitor vibration ? | ]|[ GorE | Multi-Way | 2 | 26th March 2007 10:26 PM |
| tube vibration | smak | Tubes / Valves | 8 | 19th January 2006 05:25 PM |
| Vibration Control for UcD 700 | serengetiplains | Class D | 9 | 4th January 2006 05:56 AM |
| Major Vibration | Phrozen06 | Car Audio | 4 | 18th August 2005 02:36 AM |
| Page generated in 0.07189 seconds (72.77% PHP - 27.23% MySQL) with 10 queries |
