Need help with my ST70, decrease in one channel
Old 17th December 2008, 01:32 AM   #1
JayH3 is offline JayH3  United States
Default Need help with my ST70, decrease in one channel
I am having a problem with my ST-70 build which consists of the following: DIYtube driver board, tube rectified power supply board and transformers from Triode Electronics, 12ax7, 12au7, and e34l's.
The problem is that the volume is greatly diminished in the left channel. It started about two weeks ago when everything would play fine for about an hour then the channel would cut out. Since then it has gotten worse and worse until now when the left channel is immediatly quieter than the right.
What I have checked:
changed all driver tubes,
Biased and Moved power tubes around,
tightened tube sockets,
checked all wiring,
shorted terminals on volume pot,
Compared DC resistance of left OPT to right OPT
Compared resistance of resistors on driver board between channels.
I am sortof new to this stuff so I am out of ideas. What else would be a good idea to check. Is there any way to check capacitors without a capacitor meter?
Thanks.
Old 17th December 2008, 03:26 AM   #2
HollowState is offline HollowState  United States
HollowState's Avatar
The next logical step is to make comparative voltage measurements between channels. (Amp powered on, speakers connected and no input)
Need help with my ST70, decrease in one channelHide this!Advertise here!
Questions about how to decrease the PASS A-40 amplifier into a class AB amplifier. novtango Pass Labs 4 14th February 2018 05:11 PM
ST70 clones hfh Tubes / Valves 8 12th August 2009 01:04 AM
Need help with my ST70 JayH3 Tubes / Valves 7 23rd May 2008 12:56 AM
How to decrease this voltage? sunny Power Supplies 8 31st December 2006 10:33 PM
How to decrease the voltage? sunny Everything Else 19 27th December 2006 01:32 PM
