diyAudio Sponsor
Old 16th December 2008, 12:26 PM   #1
Default Kt88 Se
Hello!
I am going to build my first amp, and I have some questions to ask.
I googled and found only Mikael Abdellahs and related ultralinear connected amps using KT88 in single ended, but i would need cca 25w of output so I was thinking about pentode operation. I found in svetlana datasheet that with anode at 400V, G2 225V, and anode I 87mA yields 20W output.
Now the question is how to get constant G2 voltage from PT?
Idle current of G2 is 4mA and 18mA at max signal. So if I lower the voltage from B+ cca 400V to 225V with resistor ther will be great differences in voltage between 0 and max signal. Should I ask my PT manufacturer to add extra taps for lower voltage?
Can I get make this amp working at 440V at anode with cathode bias cca -20 V so voltage across the tube is 420V and higher G2 Voltage so the anode current is 100mA. That would give 42W plate dissipation and probably 24W output?
Thanks!
Miha
SE KT88 Amp Cassiel Tubes / Valves 50 24th March 2011 08:33 PM
Help - CFB in a KT88 SE amp Drewaudio Tubes / Valves 4 30th January 2007 04:36 AM
Kt88 Se hacknet Tubes / Valves 9 10th September 2004 08:19 AM
Drd Kt88? hacknet Tubes / Valves 13 26th August 2004 03:41 PM
Would it be possible? OTL/OCL KT88? Layberinthius Tubes / Valves 4 24th January 2004 11:31 PM
Page generated in 0.07041 seconds (69.06% PHP - 30.94% MySQL) with 10 queries
