diyAudio Sponsor
Old 14th December 2008, 04:43 PM   #1
Question Loudness Control Calc - Help Please
Hi!
I have totally broken 500k volume control potentiometer with tap from the middle for loudness control. I cannot find 500k anywhere, but I can get 100k-250k (with the tap) from vintage SS amps. The question is - anyone may help me recalculate values of caps used in loudness control - C14 and C15. Additionally, since input resistance of volume control block will be at least twice as low, coupling cap C13 needs to be changed, too, I believe, from 0.02 ukF to 0.033....0.047 ukF as per high-pass filter calculation (corner freq. 19.3 ... 13.6 Hz).
May this change affect somehow low-cut filter after volume control potentiometer?
Thanks in advance for any suggestion(s).
Tone Control with Loudness ? thoronx Solid State 43 2nd March 2011 05:26 AM
Where is the error with this ohm's law calc? riotubes Parts 19 24th November 2006 06:33 PM
Looking for info on loudness control normanjr Tubes / Valves 5 26th September 2006 05:43 PM
loudness control maylar Solid State 6 28th March 2004 05:12 AM
TI-Calc speaker building Yoda Multi-Way 1 16th April 2002 01:44 AM
Page generated in 0.06751 seconds (67.53% PHP - 32.47% MySQL) with 10 queries
