diyAudio Sponsor
Old 13th December 2008, 03:44 PM   #1
waam68 is offline waam68  United Kingdom
Default 5U4 Darling power TX advice needed
Hi
I just picked up four NOS 1626's dated 1942 for peanuts & as my vintage speakers run very loud with a 3W 6B4G amp I'm considering having a go at a <1W Darling as my first point to point build using this schematic:
http://www.audiohobbyist.com/images/...16265u4sch.jpg
I'm planning to use the small 5K 15ohm Edcor OPTX I have left over from another project & a NOS svetlana 5U4 from the junkbox. Ideally I would like to recycle an Edcor Power tx I have spare...it's an XPWR106-240 550V 125mA Center Tapped (2* 275v and a CT) & 6.3V 4A. The schematic calls for 240v ...is this power tx any use for this project, I know I would need a separate heater transformer. I am slowly learning but my first 2 amps (which amazingly work well) were both built off PCB's & had manuals!
Mike
Old 14th December 2008, 03:43 PM   #2
would it be better decoupling the supply ? (of first tiode)
as this : http://www.drtube.com/schematics/fen...-5c1-schem.gif
(anodic current of 6SJ7 are filtered by 8uF Cap. and 25K resistor)
bye
Old 14th December 2008, 07:15 PM   #3
Klimon is offline Klimon  Belgium
Take a look at the DC Darling amp; the dedicated power supply uses a transformer with the same specs as yours. http://www.geocities.com/TimesSquare/1965/darling.html
You'll like the sound of those little buggers
Simon
Pioneer A400 pre-power seperation advice needed metako Solid State 17 1st June 2009 12:28 PM
Advice needed about Lexsen power - photo attached Brit01 Solid State 2 28th July 2008 09:05 AM
HV SS bench top power supply, advice needed panos29 Tubes / Valves 11 19th December 2006 07:06 AM
Advice Needed - Power supply for Ack! dAck! TonyDasilva Digital Source 2 17th July 2005 12:50 AM
pre / power advice needed! RevF Solid State 3 15th December 2003 11:11 PM
Page generated in 0.06910 seconds (70.79% PHP - 29.21% MySQL) with 10 queries
