diyAudio Sponsor
Old 12th December 2008, 11:24 PM   #1
Default Please add to my confusion re stepup transformers
Hey Guys
I just bought an ortofon Rondo red.
Internal Impedance = 6 Ohms
recommended load impedance 10 - 200 Ohm.
Output Voltage 500 Micro Volts
I must admit to feeling a bit of a bonehead trying to wrap said head around which transformers to get (some say sowter 8055 then others say a different sowter 9750 low z etc)
Can anyone shed light on which sut they have used and also what else needs to be used... for instance a zobel network needs to be wired in on a sowter 8055.
I just have trouble understanding the ratios and which tranny i need etc etc
My phono stage is a c3g/6sl7 one with a 47k resistor across the input. I am willing to change that if needed (the resistor that is)
Nick
"Better to say nothing and keep them guessing than to speak and remove all doubt."
Old 13th December 2008, 12:32 AM   #2
dsavitsk's Avatar
http://www.intactaudio.com/forum/viewtopic.php?t=752
http://www.ecpaudio.com
Old 13th December 2008, 03:05 PM   #3
EC8010 is offline EC8010  United Kingdom
EC8010's Avatar
The 8055 will work just fine with a 6R cartridge. Have a look at the Sowter site and it will tell you which Zobel network to use to optimise the transformer for that cartridge. The 1:10 step-up ratio will give you 5mV - a healthy signal. Almost all transformers need a Zobel network, it's just that they don't always know it. And yes, I use 8055.
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference...
Old 14th December 2008, 10:28 AM   #4
Default Thanks
Of what I read the Sowters are ok.. Although I wonder re the Lundahls.
Will let you know either way
Thanks again
Nick
Transformer stepup question biovizier Solid State 1 30th December 2006 12:42 PM
stepup 12 to 15v perivision Car Audio 10 14th March 2006 10:10 PM
WTS: AMPLIMO TM3 (Used) 1:15 Stepup Transformer Richardgreat Swap Meet 0 12th April 2005 08:42 AM
Placement of MC stepup tranny. mattjk Analogue Source 2 17th March 2005 06:22 AM
ESL amp with 1:4 stepup transformer Bas Horneman Planars & Exotics 6 13th August 2003 05:32 AM
Page generated in 0.06779 seconds (70.89% PHP - 29.11% MySQL) with 10 queries
