| diyAudio Sponsor | ||
Gentlemen,
I'm trying to slap together a DC filament power supply from junk drawer items and questionable bits of knowledge. I have a few boneheaded noob questions: Here's the deal. I have a 14 watt wall wart transformer together with a bridge rectifier and a 22 uf cap followed by about 60 ohms of resistance and another 200uf of capacitance for the 12.6 volts I need. I still have a quarter volt of ripple. So I suppose I should substitute a choke for the resistance, right? I pulled a small dime sized toroidal inductor (I think thats what it is, it lookes like a copper wire mini-doughnut) from a old circuit card and put it in the circuit to absolutely no effect. The impedance is only 1.8 ohms! Is it fair to use the formula for inductive reactance to back out the inductance? If so it's 1.8/(2*pi*120) or .0024 Henries. Can that be correct? I know I need about 3 Henries. I don't get it, what value would such a small inductor have in any circiut? For that matter, is this thing even an inductor? Thanks |
#2 |
You're probably saturating the poor thing. To be effective at that low frequency and that high current, you'll need a core the size of a softball at the least to get an effective 3 henry inductor.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache |
#3 |
Yup. I get it now. PSUD2 and the Antique Electronic site clearly illustrate that my approach is not practical due to the size and cost of the inductor due to the current requirements. I'll need to use a regulated supply. A good lab experiment though.
The low voltage regulator kit from GlassWare looks like a real bargan. I think that is the ticket. |
#4 |
Load resistance divided by 1200 will get you the Henries needed for a particular circuit. If you know the load resistance then you know the current, in fact you probably need to know the current to figure out the load resistance. Any way you figure out the different values this formula is real easy to remember and works pretty well.
Craig |
#5 |
Thanks craig. The load is a 6PN1 - 600ma at 6.3 volts. That should be 10.5 ohms. Using your formula that is only 0.005 henries. Is that correct?? PSU2 is not too happy with it.
#6 |
To be honest with you I've only used that formula for high voltages, ie 400 @ 15 ma, which ends up being a 22 henry choke. It shouldn't make any difference though. Look at the chokes in solid state amps, they too are in the mH range. For your circuit I got almost 9mH. Try googling for other formulas and see what you get, there are many out there. My friend is a transformer engineer, he came up with the same figure I did for my 22 Henry choke but used a different method. There are more ways to skin a cat but the cat always ends up skinned.
Craig |
#7 |
Check out Hagerman Technology, using that formula I got 9.3mH. There you fill in blanks so not sure what formula is. But the cat in still nekked!
Craig |
| Tuner filament supply question | rdf | Tubes / Valves | 3 | 6th August 2007 06:48 AM |
| Parallel vs. series filament supply - or another filament idea | engels | Tubes / Valves | 11 | 13th May 2007 01:06 PM |
| DC filament supply LC or CL | TBM | Tubes / Valves | 1 | 7th August 2005 07:26 PM |
| Switching power supply & filament | Aiace | Tubes / Valves | 2 | 29th June 2004 12:18 AM |
| DC Filament power supply | oldstyle | Tubes / Valves | 26 | 2nd November 2002 01:26 PM |
| Page generated in 0.08719 seconds (75.90% PHP - 24.10% MySQL) with 10 queries |
