diyAudio Sponsor
Old 12th December 2008, 07:54 PM   #1
Default Major Hum Problem
Hi All,
I have just finished building myself an SE-5W tube amp and have a Major hum issue. I have wired it so the chassis earth is isolated from the ground. Yet when I have my fingers on the strings of my guitar and put my toe on the chassis of the amp the hum is greatly reduced. Where am i going wrong? I always thought it was best to isolate the ground from eath on a tube amp.
Any other ideas where the problem might be?
Old 12th December 2008, 08:23 PM   #2
HollowState's Avatar
Default Re: Major Hum Problem
That's totally backwards. The chassis of a tube amplifier should be directly connected to earth ground by a third wire. This is for safety reasons. If something inside the amp, like a transformer, shorted to the core or case, ths chassis would become hot. And possibily deadly. Shockingly uncomfortable at best.
Edit: OK, if the chassis is earth grounded but the B- is kept isolated, try grounding it to chassis. That will probably stop the hum issue.
Victor
"The supercomputer is technologically impossible. It would take all of the water that flows over Niagara Falls to cool the heat generated by the number of vacuum tubes required." ~ Professor of Electrical Engineering, New York University
Old 12th December 2008, 10:21 PM   #3
Hi-Q is offline Hi-Q  England
Hi-Q's Avatar
Is it not the case that the B- and chassis come together at one place, normally at the audio input connector? The chassis should also be earthed at this same point. I am not sure if this is the standard convention but I have seen it on many amplifier circuits.
The older amplifiers that used non split bobbin mains transformers used to earth the chassis at the point where the inter winding copper screen of the transformer was also earthed.
I suppose the best guys to answer this question are the those that have had most experience at DIY design/construction and highlights the priceless value of Forums like this one.
Les
Old 13th December 2008, 04:42 PM   #4
Yes, the chassis is earthed to the mains input, just the B- that is isolated. I understand that connecting a 100 ohm resistor between the chassis earth and B- can help reduced ground loop effects introduced by connecting B- to the chassis.
I will try this and see how it helps.
Thanks for yuor replies
Old 15th December 2008, 01:37 AM   #5
Hi All,
When the guitar cable is unplugged from the amp (ie input shorted- assuming you are using a shorting input jack) do you still have the hum problem?
Guitar pickups (especially single coil types) are great for picking up all kinds of 'hum' from things like dimmer switches and halogen light SMPS units.
Incidentally I do agree that you need to look at the safety issues other folks have raised.
Cheers
John
Old 15th December 2008, 01:42 AM   #6
If you haven't already found your way to Aiken Amps tech pages, they are worth a look, IMO.
Grounding
Cheers
John
Gaps in my horn - a major problem? wixy Full Range 6 7th September 2007 12:18 AM
Having major problem with speakers Bull Multi-Way 23 18th February 2007 08:07 PM
GainClone troubleshooting, major problem phorensic Chip Amps 6 13th June 2006 02:00 PM
Major Vibration Phrozen06 Car Audio 4 18th August 2005 02:36 AM
Page generated in 0.07623 seconds (79.72% PHP - 20.28% MySQL) with 10 queries
