diyAudio Sponsor
Old 11th December 2008, 05:22 PM   #1
nhuwar is offline nhuwar  United States
nhuwar's Avatar
Default Phono pre amp
Hi all,
Would a 6an4 be a good candidate for service in a phono preamp?
Just thinking about it and wondering what some opinions would be?
Thanks,
Nick
Old 11th December 2008, 05:37 PM   #2
dsavitsk's Avatar
mu, gm, and input capacitance all seem decent. The curves, if they are accurate, do not look particularly linear. Also, for comparable gain it requires a lot more voltage (and about the same current) as a trioded 6GK5.
http://www.ecpaudio.com
Old 11th December 2008, 06:16 PM   #3
nhuwar's Avatar
Well it was just a though. I think I'll stick with my other idea.
Which Phono Pre??? Freecrowder Tubes / Valves 1 5th February 2009 09:45 PM
DIY phono to replace roksan phono stage seroxatmad Analog Line Level 6 14th December 2008 05:46 PM
new phono stage or old preamp with phono? flohmann Analog Line Level 2 2nd October 2008 09:51 PM
Phono transformer VS Active phono pre ckwong99 Analogue Source 0 2nd November 2005 04:35 AM
Should I replace Scott 222C phono stage with Claret phono stage? Bing Yang Analogue Source 0 22nd August 2005 06:41 AM
Page generated in 0.07496 seconds (71.45% PHP - 28.55% MySQL) with 10 queries
