| diyAudio Sponsor | ||
Hello all,
I'm considering building a pair of 6550-based 60W monoblocks around the Acrosound schematics shown on page 13 of this .pdf (High Power Ultra-Linear Williamson): http://www.pmillett.com/file_downloads/acrosound.pdf Does anybody have any experience with this circuit? What, if anything, is there to look out for? Are there any glaring mistakes in the schematic? I've considered several designs by Joseph Norwood Still, but his designs seem to push several components - namely tubes and power transformers - to their limits (I'm not a fan of forced-air cooling). I have a pair of Hammond 278CX transformers just waiting to be used, and I think they'd be quite well suited for this project (if not a bit underrated!). Thanks in advance for any wisdom anyone could share on this subject. |
#2 |
What I found most interesting about your attached PDF is that it cost 2 cents postage to mail it back in the day! A very fun read...
Sorry I am too much of a newbie to critique the circuits. |
#3 | |
1) Use a full wave bridge in the bias supply. 2) Use at least a 100ufd cap after the choke. 3) Replace the single 10K bias/balance pot with two seperate ones. One for each tube. Also loose the 25K/5W pot to a fixed resistor. 4) Put 10 ohm resistors in the output cathodes in order to measure current with a small onboard meter and switch. And loose the fuses. 5) (Extreme and basically designers choice) Rebias the 6SN7 driver stage to allow direct coupling the input thus eliminating two coupling caps. Go all out with a CCS in the cathodes. This may or may not make it sound any better. ![]() BTW, forget about the 100W amp on page 11. The input can't work right as shown. A 6SN7 cannot work into a 2700 ohm load. But it would work with a (transistor) current source in each cathode. Victor
"The supercomputer is technologically impossible. It would take all of the water that flows over Niagara Falls to cool the heat generated by the number of vacuum tubes required." ~ Professor of Electrical Engineering, New York University |
#4 |
Thanks for the input, guys. I have absolutely no desire to build a 100-watt monster amp with 6146's, even thought I have scads of those tubes (they're currently set aside for my HW-101 ham transceiver).
Another question does bug me though. The acrosound schematic calls for the TO-330 output tranny, which has a primary impedance of 3.3k. The closest thing I can get in reasonably-priced iron (e.g. Edcor or Hammond) is around 4.3k. I have a pair of Hammond 1650R's, but they're 5k. Any suggestions? Thanks again! |
#5 |
Yes. Look at the impedance curve of any speaker, think about the transformation ratio and what the plate load will REALLY be, then stop stressing about it.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache |
#6 | |
For whatever transformer you use other then a TO-330, some slight adjustment of the feedback 47pfd capacitor will probably be necessary when observing a square wave. But this is tweeking after you get it built and running. Victor
#7 |
Thanks, Sy and Hollowstate.
Yeah, the "3300" was definitely an oversight on my part. You guys are right about the mismatch. A friend of mine who repairs MRI machines says it really shouldn't be a huge deal. I really don't feel so bad about it now. I agree with you on most of the circuit changes. The full-wave bridge is definitely an improvement over the simple diode. I was also planning to use improved filtering in the power supply, and to implement the metering scheme you suggested. The 25k pot in the bias supply will probably remain, as the possibility of using EL34's intrigues me. The 5W rating does bother me. Why so high? This is a bias supply running less than 50V at what I would suspect to be very little current. As for the re-biasing of the driver stage... well let's just say I'm not a 'newbie" as such, but I'm not quite ready for prime-time either! I've read a few good things about Edcor iron. Do you have any personal experience with it? Thanks again! |
#8 |
For an interesting tutorial on using load lines to determine the OPT, do a search for Patrick Turner Audio.
#9 | |
Hi hollowstate,
Regards, Tom Schlangen
If in doubt, just measure. |
| Acrosound High Power Williamson - HELP!!!! | zman3 | Tubes / Valves | 25 | 11th January 2009 11:00 PM |
| F.S. acrosound to-300 pair | mctavish | Swap Meet | 3 | 20th September 2008 11:38 PM |
| Is Acrosound T-330 really good? | pchw | Tubes / Valves | 18 | 26th November 2007 06:00 PM |
| Acrosound Archive | diamondsouled | Tubes / Valves | 0 | 16th November 2007 07:30 PM |
| Acrosound TO-330 output transformers | Bakunin | Tubes / Valves | 1 | 20th December 2005 08:30 PM |
| Page generated in 0.10874 seconds (81.54% PHP - 18.46% MySQL) with 10 queries |
